LT4 Intake Question?
Old Aug 18, 2004 | 11:31 PM
Bow94z's Avatar
I was wondering if i bought an LT4 Intake....would this give me any more rwhp gains at all on a mostly stock motor...other than mods listed.
just very curious.. can buy one real cheap
Old Aug 18, 2004 | 11:35 PM
Spinner's Avatar
Re: LT4 Intake Question?
Wont fit.
Old Aug 19, 2004 | 06:07 AM
rskrause's Avatar
Moderator
You will lose hp as the ports won't line up, though it will bolt on.
Rich
Old Aug 19, 2004 | 09:20 AM
Perhaps a little more info...
Mechanically, there is an interference between the LT4 intake and the valve cover rail on the LT1 head. Either can be machined, and they can be bolted together.
But, you will see no change in performance. In actuality, although the LT4 heads have 0.100" raised runners, the LT4 intake does not have these raised runners. What it does have when it comes from the factory is a passage and profile that is virtually identical to the LT1 intake. What is different is that the LT4 intake has more metal on the top, to allow the ports to be matched to the LT4 heads, and it takes a substantial amount of porting, both in the runners and at the TB connection to get the LT4 intake to support well-ported LT4 heads.
It is a nice shade of red though
[EDIT]... You might want to try the "search" function for questions like this... I am willing to bet that "Arnie", myself and several others have answered this question at least 50 times over the years.
Old Aug 19, 2004 | 10:44 AM
383Z4ME's Avatar
Gee Fred, I thought the first thing you do is bead blast the red powder coat off and weld it up for porting? Was I supposed to get it recoated red?
Rick
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
