Lt4 intake maifold question
Re: Lt4 intake maifold question
Why do you two think it wont fit???? The LT4 intake ports are the same size and location as the LT1.
MOST people believe the LT4 intake is very different when in reality there is a little more aluminum on top of the ports and it is red, not the earth shattering differences you previously believed huh?
Originally Posted by Fastbird93
Ummm.....ever tried to sit an LT4 intake down on LT1 heads while on a motor???
Now I have not seen direct info on LT4 intake with Trickflow heads, BUT once you understand the differences between the LT1 and LT4 intake you have a MUCH better understanding of what the potential issues are and how easily they are remidied or wether it is worth persueing atall. Spoonfeeding yes and no answers does little good, make people THINK and the whole hobby can continue to move forward.
I am running the LT4 intake and Trickflow heads on my 355"LT1. The Trickflows are raised runner heads designed to be used with the LT4 intake. There is alot of material that needs to be removed from the intake to make it flow enough to support the ported Trickflows. Later Clint
95chwagon
Jan 13, 2015 09:19 PM
