lt4 intake
Old Jan 27, 2005 | 05:18 PM
badasschevy625's Avatar
lt4 intake
will this bolt up to a stock lt1 and will i notice any gains?
Old Jan 27, 2005 | 05:38 PM
Firehawk_Dude's Avatar
Re: lt4 intake
I think you have to have the heads with it (and vis versa). Have to do the intake w/ LT4 heads and LT4 heads with LT4 intake.
Someone correct me if i'm wrong please.
Other then that, yes think it should be a direct bolt up.
Old Jan 27, 2005 | 05:45 PM
Re: lt4 intake
Might want to try a "search"..... this question has been beat to death perioically. In a nutshell.... there is an interference between the top of the LT4 intake manifold runners and the LT1 head valve cover rail. One or the other needs to be machined to get the correct fit. Then you will have a net gain of "0", because the "as cast" ports in the LT4 intake are the same as the ports in the LT1 intake, even though the head ports are different. Doesn't make any sense, but that's the way it is.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
