LT4 Hotcam!
Old Aug 21, 2006 | 05:26 PM
  #16
1quickTA's Avatar
Re: LT4 Hotcam!
I can't say what a hotcam is like without rockers but I love mine with my 1.6RRs.
Old Aug 21, 2006 | 06:30 PM
  #17
Severous01's Avatar
Re: LT4 Hotcam!
if you're tearing it apart, do it right. if you're just doing the cam the just do the cam. if you're going to tear it all down, replace everything you're breaking down....just the heads, do all the headwork, heads and intake...port match the intake and throttle body, get new rockers/springs/pushrods/lifters and guideplates if you need them.
Old Aug 21, 2006 | 06:31 PM
  #18
Formula594's Avatar
Re: LT4 Hotcam!
Im thinking about throwing in a LT4 hotcam soon, what about fuel injectors and would a 52mm tb help out any, and I would be running 1.6rr's.
Old Aug 22, 2006 | 01:09 PM
  #19
LT1Mike's Avatar
Re: LT4 Hotcam!
20-12524653 LT1 Intake Manifold Gasket set $32.49
20-10128343 LT1 Water Pump Gasket (2 required) .75 each
20-10128293 LT1 Timing Cover Gasket 3.99
Ill order these too... thanks stevo for the part numbers.... This will complete the install
Old Aug 22, 2006 | 01:35 PM
  #20
526 SS 96's Avatar
Re: LT4 Hotcam!
Formula594-
Simply install the hot cam kit as it comes. Replace any wearables (timing chain) or consumeables, (gaskets) and leave everything else alone. A big TB will only kill your responce and torque. Big TB's are only effective with larger cams and agressivly ported heads, so in this case it would be a waste of some serious coin (I bought the AS&M 58 when I finally out grew the stocker). Ditto for the injectors.
Old Aug 22, 2006 | 05:27 PM
  #21
Formula594's Avatar
Re: LT4 Hotcam!
Thanks alot for the suggestions 526 SS 96.
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
