lt4 hot cam kit guys, enter please
Old Sep 26, 2005 | 08:01 PM
slowZ's Avatar
i have had this hot cam kit and put about 5,000 miles on it. i just recently heard the valve train get louder and noticed some lost performance. so me and my brother pulled the valve covers and found some rockers a little loose, but what concerned me is the center part of the rockers where the bearings are i found most of them had what looked like aluminium shavings in some grease coming out of there. have any of you guys noticed this or heard of this happening?
Old Sep 26, 2005 | 10:07 PM
FastZinTennessee's Avatar
Re: lt4 hot cam kit guys, enter please
Never heard of that. I put about 10k miles on my HOTcam kit and when removed the rockers looked like new.
Old Sep 26, 2005 | 10:38 PM
Evil Eric's Avatar
same here, im about 8000 miles on mine and no problems, do you have hardened pushrods ?
Old Sep 26, 2005 | 11:29 PM
Red on Red WS6's Avatar
about 20,000 miles and no problems either. How many turns did it take to get to zero lash? Were they installed correctly?
Old Sep 28, 2005 | 06:58 PM
slowZ's Avatar
no, no hardened pushrods. im not sure how many turns it took to zero lash on install, b/c i had a shop do it. but when i checked them the ones that were loose only took at most a 1/4 turn. i cant understand why that stuff would be coming out?
Old Sep 28, 2005 | 07:08 PM
Z28barnett's Avatar
The roller bearings could be breaking down inside the arms.
You might check the valve covers for wear, make sure that the arms are not rubbing.
Then take an arm off and work the bearing by hand, if it feels rough the bearing is bad.
If you don't find anything else causing this the arms should be pulled and rebuilt / replaced.
Sucks should not be happening.
Z28
CamaroHeed
Mar 18, 2020 09:50 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
WildRidez
Jan 16, 2015 03:10 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
