lt4 hot cam install question
Old Aug 29, 2010 | 09:23 PM
jmjeeps's Avatar
Hey all, im going to be throwing an lt4 hot cam in my lt1 next weekend, im wondering if the length of the pushrods is going to change, or if i can re use my stock ones? I will be buying a set of roller rockers soon, but theres a good chance i wont have them when i put in the cam, so i will be re using the stock solid rocker arms for now.
Thanks for any help!
Old Aug 29, 2010 | 09:50 PM
Pushrods should not be an issue, if you are not touching the heads. The stock rockers might not be so fond of the increased lift, though. You should very seriously think of changing the valve springs before doing the 1.6 rockers that the HOT cam setup normally uses. My preference would be to do it all at the same time or either do the valvetrain upgrade before the cam-not the cam before everything else.
Old Aug 29, 2010 | 09:54 PM
jmjeeps's Avatar
Thanks Shoebox, I really appreciate the help, i will go that route then. Im hoping to find a decent set of used 1.6's. I think iv found them, i'v just got to get them paid for and shipped (this week hopefully). Also, thanks for the kick a$$ website, i have used the diagrams and tech write ups more times than i can count on my fingers and toes! Your web site rocks!
Matt
Old Aug 29, 2010 | 10:43 PM
Jameslt1TA's Avatar
I would definitely do 1.6 rockers and some better valve springs. I take it that you already have the cam or i would just say to buy the whole hotcam kit.
Old Aug 30, 2010 | 05:01 PM
camz28ryan's Avatar
i put the same cam in my lt1 and i kept everything stock and i havent had any problems at all, really happy with the cam, lots of work though! goodluck!
Old Aug 31, 2010 | 09:24 AM
Mystery Bird's Avatar
Matt
Just a thought, if you use Shoebox's site a lot consider donating a few bucks to help keep it going for all of us.
I had the Hot Cam kit with stock pushrods for a couple of years with no problems. Good kit for the money.
Old Aug 31, 2010 | 11:04 AM
93zder's Avatar
How much power are these hot cam giving LT1's?
I was under the impression they were not that great for a power upgrade - maybe a bit of an old school cam?
Old Aug 31, 2010 | 11:29 AM
GRIDERMAN87's Avatar
It really depends on what else you have done to the car, its a good cam its just not a radical upgrade its positively a big step up from the original cam tho. rough estimate is 20 -25 hp or somewhere around there.
Old Aug 31, 2010 | 02:42 PM
STRYKER's Avatar
A looong time ago (1998ish), I put a LT4 hotcam in my old 95 Z and that was the only thing I changed. Granted the weather changed a little bit but I went from a consistent 13.99-14.02 to a 13.63-13.69. I have no clue where the time slips from then are but I do still have them.
Old Sep 2, 2010 | 11:04 AM
93zder's Avatar
That's a good increase for a mild cam.
I have heard it's not uncommon for an LT1 with bolt-ons and a mild cam to get into the 12's.
Old Sep 3, 2010 | 12:21 PM
GREGG 97Z's Avatar
All #'s below were with the hotcam kit and bone stock untouched heads plus all the usual bolt ons. I have since done work to the heads, havnt dyno'd it again though. Pcmforless programming was a big part of those #'s.
And I agree, don't just throw this cam in and run your stock springs/rockers. At a bare minimum use lt4 springs, and install some roller rockers. If someone is going to use this cam I can't see why they wouldn't just buy the HC kit.
A lot of people will recommend upgrading the lt4 springs which is a very good idea.
I overreved mine on a missed shift years ago and ended up with two wrecked lifters and cam due to the lt4 springs.
Old Sep 3, 2010 | 09:50 PM
STRYKER's Avatar
That is what I thought too considering I didn't change the tune, rockers, or anything.
Old Sep 4, 2010 | 06:39 AM
GreenZLT1's Avatar
Ran a 13.1 here with the car going "flat" at the end of the 1/4.
LeftoverChinese
Jan 14, 2024 03:03 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
