LT4 Hot cam?!?
Old Apr 28, 2009 | 11:33 AM
Tanner_94_Z28's Avatar
LT4 Hot cam?!?
i found a new LT4 hot cam for my car and i know the cam will make my car so much faster....so i was wondering if i installed the cam in my motor just the cam itself would i have to change anything else in my motor or can i just swap out the cams?
Old Apr 28, 2009 | 11:34 AM
95ltslow's Avatar
Do some research on here for cam set ups. You will quickly see what has to be replaced.
Old Apr 28, 2009 | 02:17 PM
LearJet's Avatar
There are much better choices than the hotcam too.
Old Apr 28, 2009 | 03:21 PM
maybe2fast's Avatar
CC503, more power, same tune (mail order)
Old Apr 28, 2009 | 10:20 PM
twcblackhand6970's Avatar
On the subject, you HAVE to change out springs and spring hardware.
However, most people do springs, roller rockers, pushrods, lifters. Up to you.
Now to add on to what the others are saying. The hotcam is rather small, if you want a small jump with no low rpm surge then that'll be nice, but if you want to make 320rwhp you'll need something bigger like the cc503 which is a popular choice. I chose a bigger cam than most recommend which was the cc306. It is considered too big for stock heads, but I plan on getting LE2 heads soon, and with stock heads revving to 6200 getting 330rwhp (damn a4) is damn good for a cam talked down on soo much.
Old Apr 29, 2009 | 06:00 AM
SnakeOiler's Avatar
BS - there is plenty of power to be had with a hotcam.
Old Apr 29, 2009 | 09:07 AM
powerslide350's Avatar
You can make 320 easy with a HK. You will want some long tube headers as well as a y-pipe/ catback
Old Apr 29, 2009 | 09:30 AM
wrd1972's Avatar
Yup. Bolt ons and a hot cam is easy 320 RWHP.
Old May 8, 2009 | 01:18 PM
95 WHITE TRANS's Avatar
I just got done with the complete lt4 conversion INCLUDING THE WEAK LT4 SPRINGS . This kit ROCKS.
Old May 8, 2009 | 01:25 PM
93FIRETURD's Avatar
320 RWHP Is easy to get out of a good hotcam setup. I love the hotcam it is great it is perfectly street mannered and loves eating cam-heads-small shot mustangs all day long. Look into a good set of springs the LT4 springs are OK but there are plenty of choices that are better. A good set of roller 1.6 rockers will really help as well and are recommended. Good luck with the setup and keep us posted.
Old May 8, 2009 | 01:37 PM
I have the 1.6 rockers, roller lt4 timing chain pcmforless tune 2600 vig stall.The whole ten yards.I love the way it sounds slp headers cat back.I left the lt4 springs on cause i got the lt4 heads with the hollow valves.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
