lt4 heads/intake worth it?
Old Jan 18, 2005 | 05:27 PM
unvc92camarors's Avatar
hey, i was planning on porting my lt1 heads/intake this winter but i'm wondering if i should go bigger
right now, i'm just gonna port the heads and intake, and throw a custom cam in (after seeing how well the heads flow)
how much more power do you think i'd make if i went to lt4 heads/intake with a custom cam?
this is just going on a stock bottom end right now
not sure if i'll go stroke or bore it in a couple years or not
and i'm trying not to spin above 6500
so basically, would i gain flow everywhere on the charts, like even at low lift? i don't want all my increased power way up in the rpm range
i guess that's all the questions i have right now
thanks in advance
Old Jan 18, 2005 | 06:41 PM
94red's Avatar
Re: lt4 heads/intake worth it?
Your money would be better spent on getting your own heads ported. The stock LT4 is an improvement over the stock LT1 but shoot, they cost about 1400 don't they? I would say get a LE2 package for about the same money and you will be better off. Also get something that works with your current bottom end. When you upgrade to a stroker you can put in a bigger cam and have the heads touched up if you want.
Old Jan 18, 2005 | 06:52 PM
96capricemgr's Avatar
The only way I would consider the LT4s is if you were looking too port them when and if you do a stroker and want it too be a serious motor. For now though it reallu looks like ported stockers a money better spent, they will be cheaper and flow more than stock LT4s.
Old Jan 18, 2005 | 09:11 PM
well no
i meant like porting the lt4 heads/intake rather than the lt1 heads/intake
basically, i'd be homeporting (after practicing on some bad heads of course)
i just wanted to know if the heads/intake were worth the money AFTER i port them and suit a custom cam to them
thanks
Old Jan 18, 2005 | 09:14 PM
DavesLT1's Avatar
if you're just going to buy the LT4 heads to port them why not just buy some AFR ported LT4 heads and find an intake to match port?
Old Jan 18, 2005 | 09:20 PM
how much are the afr's?
i really wanted to see what i could do with the heads and i wanted to keep my rpm range somewhat down (as in still making good power down low)
Old Jan 18, 2005 | 09:44 PM
sssalah's Avatar
The good afr lt4 are like 2400, and a set of proffesionaly ported lt4 that flow similar will probably be cheeper if you started with bare castings. IMO yo don't need anything flowing more than 275 cfm for a stock dispacement motor operating at or lower than 6500 rpm, and that is doable with lt1s.
Old Jan 18, 2005 | 09:59 PM
that is the answer i was looking for
thank you
looks like i'll just pick up a junk lt1 head or 2 and practice porting on them
thanks again to everybody for the replies
Old Jan 18, 2005 | 11:52 PM
T/A#4's Avatar
Talking Re: lt4 heads/intake worth it?
For Sale: LT4 heads, mild port job, port matched , redecked, Comp. Beehive #918 springs & retainers, good to .600 lift, valves hand lapped in. Springs & retainers never run.= $1100.
LT4 intake, port matched, some porting, bored [not ground] to accept 58mm TB, erg block off plates [2] by TPIS $325, new ,never on any engine.
58mm TB, BBK, new $250.
Old Jan 18, 2005 | 11:53 PM
T/A#4's Avatar
Bolt on 40+ hp w/ stock cam
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
blaze309
Sep 8, 2015 05:27 PM
mark0006
Aug 29, 2015 09:45 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
