LT4 & ED timing chains
Old Mar 20, 2005 | 09:41 PM
$hawn's Avatar
Are the ED timing chains and the LT4 chain any different than a factory LT1, and importanly any stronger, sense I dont want to switch to the later style these chains might be my only options and the LT4 is about 20$ more than the chain in the ED set.
Old Mar 22, 2005 | 12:28 AM
$hawn's Avatar
Re: LT4 & ED timing chains
I guess that knocks out the extreme duty chain cus it's a double roller. So is the LT4 a double roller though. Also anybody use the cloyes C509 chain?
Old Mar 22, 2005 | 01:24 AM
Spinner's Avatar
LT4 ex chain is a ROLLER chain. A single roller.
And it also costs 4x more then a good cloyes/rollmaster double roller. I use a double roller comparable to that c509. It cost me $60, will last forever, is not a part I ever worry about breaking, and will keep accurate time for much less then the overprived lt4 chain.
Old Mar 22, 2005 | 01:32 AM
madhatter's Avatar
Do you have a part number for the one you run?
Old Mar 22, 2005 | 01:39 AM
Spinner's Avatar
Its the EX components double roller combination motorsports sells. Beautiful and BEEFY piece.
Old Mar 24, 2005 | 11:01 PM
$hawn's Avatar
On the summit web site it said it was a double roller, I'v never seen one so I dont know, a lot of people seem to be ok with those, and I dont run my car hard but the chain is about 60$ and that cloyes C509 I can get for bout 25$, but is it any better than a regular stock replacment chain?
Old Mar 27, 2005 | 06:56 PM
$hawn's Avatar
I think my plan is to get the extreme duty chain and crank gear, and buy a stock replacement 92-94 cam gear. I shouldnt have any trouble with that combo right?
Old Mar 27, 2005 | 07:09 PM
Lonnie Pavtis's Avatar
You cannot mix components.....
The LT4 is a roller & will not work with the stock LT1 style gears.
Old Mar 27, 2005 | 07:10 PM
Valkyn71's Avatar
I believe to use the double roller chains you need to use an electric waterpump?
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
