Lt4 Clutch : Need Quick Answer!
Old May 14, 2004 | 03:13 PM
z28poweredlt1's Avatar
Is the lt4 clutch and pressure plate comparable to any performance clutch's? If anyone knows leave i post I might be buying one as soon as i get some info! Thanks everyone!
-Mark
Old May 14, 2004 | 03:36 PM
Pasky's Avatar
Same clutch disk as the lt1 has a stronger pressure plate. I hear people using them all the way up to 400 hp.
Old May 14, 2004 | 03:54 PM
kgkern01's Avatar
I have heard that LT4 C4 clutch is an unsprung disk, is this true?
Old May 14, 2004 | 03:59 PM
ZDriver96's Avatar
im too lazy to go down and look and see if it doesnt have springs.. but im 99% sure it doesnt.. thats why u cant use the LT4 disc with a LT1 pressure plate.
My car had more than 400hp at the fly and the clutch would hold 1 full run fine. But if i stopped immediately and tried to do it again it would slip... By 1 full run i mean zero to 120mph.
It didnt slip if i was going through 1st and 2nd alot...
Old May 14, 2004 | 04:07 PM
madhatter's Avatar
I jsut put a new one in because mine was shot after 15k. Now the new one is barely holding.
I will be going with the LT4 PP and the single disk McCleoud next.
Old May 14, 2004 | 04:08 PM
Will a lt4 disc/pressure plate work on a stock set up? Should eveyrthing bolt right up? Just wondering becuase i have to buy soon, also, would you say that its comparable to a spec stage 1 -2? better, worse? or jsut worth it to go with the spec? Thanks
-Mark
Old May 14, 2004 | 04:11 PM
ZDriver96's Avatar
buy the LT4 clutch disc and pressure plate together.. and it will/should come with a throw out bearing. Also pick up a pilot bushing to replace your old one. Total should be 300-350.
LT4s will hold 400hp no problem and they bolt up fine to an LT1 car
KYWes
Apr 15, 2015 07:11 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
97FormulaWS-6
Aug 5, 2002 05:15 AM
