LT4 cam on stock LT1?
Old Mar 7, 2005 | 09:56 PM
13sectransam's Avatar
I found a good deal on a used LT4 cam and am wondering if I can use it with an otherwise stock engine? Meaning stock springs, rockers, heads, manifolds. I realize I won't get the full benefit from the cam, but I just need to know if it will work and how high I'll be able to rev if it does work. Thanks.
Old Mar 7, 2005 | 10:10 PM
sbs's Avatar
sbs
Re: LT4 cam on stock LT1?
If you mean LT4 HotCam, you ought to replace the springs.
If you mean LT4 stock cam, it is milder than the stock LT1 cam.
Old Mar 7, 2005 | 10:57 PM
Its a HotCam. sorry I didnt clarify.
Old Mar 7, 2005 | 11:03 PM
96m6lt1's Avatar
not exactly true the lift and duration are very close but the lt4 cam has a 115 lobe sep vs.116,117.5 that the lt1s come with stock.
the lt4 hot cam is advised to use the bigger springs,especially if you are using the 1.6 rockers,i would also change the timing chain.
Old Mar 8, 2005 | 03:48 PM
Alright. Thanks.
oldschool
Feb 9, 2016 09:21 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
