LT1 Z28 help
Old Apr 3, 2004 | 05:24 PM
shming123's Avatar
Cool LT1 Z28 help
hey... i'm new to the forum and i want to get an early-middle '90s camaro z28... Is there anything i should know about with the model years? are there any to stay away from or are better than others? Also, i am new to camaros; do they usually have any problems with anything specific or is there a "weak link" ? Overall, how reliable are they and how well can they tolerate abuse? Thanks for the help.
Old Apr 3, 2004 | 05:43 PM
RyanS_Z28's Avatar
http://web.camaross.com/forums/showt...hreadid=244765
shazaam! 4 pages of info on the LT1
Old Apr 3, 2004 | 10:49 PM
shming123's Avatar
that was great, thanks. Is there anything more? like with the trans, driveline, etc..?
Old Apr 3, 2004 | 10:55 PM
HardcoreRM125's Avatar
The power window motors blow, and the rear end is kind of a weak link if you get a manual and race it with drag radials ... If your launching on street tires, the rears usually can take some abuse. On radials though ... .
RyanS_Z28's Avatar
uhh trannys are the same 460LE (i think thats the number) for automatics and manual 6 for the other guys. the gear ratios depend on the options you selected, but i think some come with 3.23s and some with 3.73? maybe thats too high. anyways, what specifically do you need to know?
Old Apr 3, 2004 | 11:00 PM
shming123's Avatar
i am in college and this is going to be a daily driver and i am just making sure that these cars are reliable for the most part, and it seems like they are.
Old Apr 3, 2004 | 11:03 PM
RyanS_Z28's Avatar
of course they are reliable. you'll want to mod the pants off of it too. its a vicious cycle. its like well i got the cam, might as well get the heads ported, well now that im over here maybe i should port my intake, well i suppose now that we are doing air flow we might as well install a supercharger just for $hits
Old Apr 5, 2004 | 01:19 PM
IrocManiac's Avatar
Mine is a daily driver, as long as you take care of them and get one that hasn't had the **** beat out of it you should be ok. The LT1 is a strong motor...btw I'd try to find a 95 + if you can...you get the vented opti (ignition system) which is more more reliable then the previous model.
Old Apr 5, 2004 | 01:22 PM
RyanS_Z28's Avatar
well but he should just upgrade to the opti-eliminator anyway
Old Apr 5, 2004 | 01:23 PM
RyanS_Z28's Avatar
these are corvettes with different bodys. same parts for the most part. same engine, same trannys, same internals. quite a bargain
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmdeshon
Jan 4, 2015 11:15 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
