LT1 wont stay running!!
Old Feb 8, 2008 | 06:29 PM
wheelliftnpony's Avatar
my 94 z28 will fire for a second on startup, briefly idles(1 second), and shuts off.. im leaning toward bad fuel pump, but im not sure. the battery went dead from turning it, but when jumped it stayed running without missing until i shut it off. i tried to fire it back up and it would do the same thing it was doing. what is going on? thanks
Old Feb 8, 2008 | 06:38 PM
Pontiac_97's Avatar
battery?
Old Feb 8, 2008 | 06:43 PM
no it turned strong i dont think it would be the battery
Old Feb 8, 2008 | 06:49 PM
my94blackz's Avatar
security light on?
Old Feb 8, 2008 | 06:53 PM
actually it is.. im guessing those are related... please, enlighten me
Old Feb 8, 2008 | 07:04 PM
security lights been on a while tho and it ran like that until the other night
Old Feb 8, 2008 | 07:20 PM
maybe2fast's Avatar
pass key problem
Old Feb 8, 2008 | 07:30 PM
how do i fix or bypass?
Old Feb 8, 2008 | 07:35 PM
lt1car's Avatar
sounds exactly like mine.
Its a vats problem. Vechile anti theft system (why your lights on)
You can bypass it with a $30 module on ebay. Comes with easy diagram for installing. It installs on your PCM.
I installed it and she fire right up.
.....but before that it would turn over, start, then run for about 1 sec, then stall out. I could repeat that over and over till the battery was dead.
It could be the pass key problem to, but thats a bunch of work trying to solve the problem.
If the Vats dont work, do a search on bypassing the module in the right side of the glove box (when you pull the glove box out). Look up on shoebox's website. He has a very easy diagram. You just take 2 wires and jump through it.
I had to do that after I bought that module from ebay (about a year after) then it worked fine.
its really hard to diagnos these stupid no start problems, it was a nightmare with my dash all riped apart trying to find the problem. I wish you luck!
Joe
Old Feb 8, 2008 | 07:40 PM
i think you got it. symptoms are the exact same. thank you very much for the help. would i be able to write you if i have any more questions? THANK YOU!!!
Old Feb 10, 2008 | 12:31 PM
lt1car's Avatar
no problem. I will check back to pm's often as I can.
I still have all the old pm's from a guy helping me on here.
oldschool
Feb 9, 2016 09:21 PM
ddr698
Jan 9, 2015 10:05 AM
GhostZ28
Dec 7, 2014 11:53 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Rich_z28
Sep 13, 2002 03:35 PM
