lt1 won't start
Old Aug 20, 2012 | 02:49 PM
  #16
tree95zlancca's Avatar
Re: lt1 won't start
I had a similar problem that I fixed this weekend. Everything would visually and electrically check out except every now and then when going to start it you would only hear 1 click then nothing but interior lights. What I found was the positive cable that has 3 wires going to it, the one going to the starter had corrosion running down under the insulation quite a ways towards the starter. Replaced the end with a new connector while removing the section of corroded wire and all is good so far.
Britbilly
Jan 7, 2015 08:49 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Collector Car
Jan 5, 2015 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
