LT1 won't start
Old Sep 14, 2007 | 03:34 PM
Rage's Avatar
LT1 won't start
LT1 turns over, hits a few times, but never starts. Any advice?
Old Sep 14, 2007 | 03:50 PM
wrd1972's Avatar
Fouled plugs, pull a plug and check it.
Low fuel pressure, put a gage on it.
Old Sep 14, 2007 | 03:57 PM
White96Z28's Avatar
FIrst, check your fuel pressure, it should be about 40PSI with the vacuum line attached to the fuel pressure regulator and about 47PSI with the vacuum line taken off of the FPR. Then check for spark. Let us know what happens when you do those two tests and hopefully we'll be able to give you some better direction from there.
Old Sep 14, 2007 | 05:08 PM
clubgm93z's Avatar
Icm ???
Old Sep 14, 2007 | 07:28 PM
dangalla's Avatar
could be a bad opti also, was it running ok before it decided to not start
Old Sep 14, 2007 | 09:07 PM
Have you scanned it for codes?
Old Sep 15, 2007 | 10:36 AM
Rage's Avatar
I'm thinking it may be the opti as well.
I have scanned it for codes and it didn't pull any up. Is it possible for the opti pigtail to go bad?
Old Sep 15, 2007 | 11:41 AM
popstoy's Avatar
check all your coil wires they tend to crack and corrode have someone wiggle them when you fire it up.
If the pins are corroded or damaged it can corrupt the Opti high and low res pulse signals. That can cause a no start. But it should also set codes. What year is your LT1 engine and LT1 PCM?
Old Sep 15, 2007 | 11:44 AM
Z-RATED94's Avatar
Your kidding right? Do you really what someone to wiggle the coil wire while trying to start the car?
Old Sep 16, 2007 | 08:50 AM
Rage's Avatar
94 for them both. I don't see any corrosion. On this model opti, the opti-spline is keyed, but is it possible to be 180 deg. out?
Old Sep 16, 2007 | 11:36 PM
Its very easy to align the splines incorrectly. Many people manage to get it installed with the "odd" tooth in the wrong position. What did you use to scan for codes?
Old Sep 17, 2007 | 10:23 PM
Rage's Avatar
I forget the name of the program, but it is on my brothers laptop. He also tuned the VATS out of the computer with it.
Old Sep 18, 2007 | 08:56 AM
dangalla's Avatar
ah come on its just a little kiss
like 50,000 volts or so
Britbilly
Jan 7, 2015 08:49 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Collector Car
Jan 5, 2015 10:58 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
