lt1 wire harness
Old Feb 21, 2008 | 11:47 PM
DelSoto's Avatar
lt1 wire harness
Will the engine wire harness for a 96 WS6 M6 work on a 94 Z28. I am doing an A4 to M6 swap. I understand that I can make mine work but the A4 harness goes for more than the M6 so I fig I can get the money back out....provide a harness for someone that needs the A4.....not have to splice wires.
Old Feb 22, 2008 | 12:11 AM
mad95z's Avatar
I think that there the same, what would make them otherwise?
Old Feb 22, 2008 | 12:25 AM
DelSoto's Avatar
I was thinking 96 was OBDII and has the crank trigger?
Old Feb 22, 2008 | 12:49 AM
mad95z's Avatar
Duh, im a little tired. I thought you meant plug wires/harness!
sorry. the main wiring harness most likley has the same basic layout but with the manual trans and ODBII electronics/sensors im sure there not directly compatable.
Old Feb 22, 2008 | 01:03 AM
DelSoto's Avatar
I'm sure it is a diff computer...wasn't sure if it had the same computer plug or not.
Old Feb 22, 2008 | 03:14 AM
Green96Z's Avatar
I'm pretty sure OBD1 and OBD2 use different plugs on the PCM. If they are the same, the wiring circuits sure aren't.
Old Feb 22, 2008 | 06:47 AM
The PCM plugs are the same and most of the wiring is the same. Still, IMHO, it would be better to get a harness of the same year. 1994s are a little different (ex. they don't have the C100 connector that 95-97s do). You would need schematics and have to rewire some circuits to make them work, if you used the later harness.
Old Feb 22, 2008 | 11:35 AM
DelSoto's Avatar
Thanks, Rob!
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Rich_z28
Aug 29, 2002 10:44 PM
