LT1 will only start once?
I tried a search, and can't find anyone else who has had this issue before.
After replacing the head gaskets in my 95 Impala, the car will only start and run on the first attempt. It starts up, sounds great, but once I turn off the car it won't restart.
After disconnecting the battery to reset the PCM, the car will start again, but only one time.
I have fuel pressure (gauge) and I am getting spark to the plugs. I guess I need a noid light to see if my injectors are firing. I also need to check and see if there are any codes.
What code could prevent the car from re-starting?
I'm stumped, any ideas are welcome.
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
