LT1 water pump... short of long style?
Old Feb 1, 2010 | 11:09 PM
Colin's Avatar
Hey guys,
I'm going to be running a remote electric water pump on my LT1. Because of this, I need to figure out whether I need a short-style alternator bracket or a long-pump style. Anyone have a clue which style bracket I would need?
My application is somewhat unconventional. Front-style motor mounts with the only belt-driven accessory being an alternator. Due to room constraints, I need to run the alternator up high near the throttle body. I just don't know whether the belt alignment is short-style or long-style.
thanks for your help.
Old Feb 3, 2010 | 12:03 AM
Colin's Avatar
No one here knows if the depth of the balancer from the block is equivalent to a short or long water pump?
C'mon guys, help me out. I really want to drive my Vega.
Old Feb 3, 2010 | 02:53 AM
RamAir95TA's Avatar
I'm curious on how you're planning to do this. The coolant passages on the front of the block will not work with a conventional remote SBC water pump - they are LT1-specific.
Old Feb 3, 2010 | 06:55 AM
The LT1 has no short or long style and the water pump is not belt driven, so it's a little hard to come up with a positive answer.
Old Feb 3, 2010 | 09:44 AM
Colin's Avatar
RamAir95TA,
I have had block plates made so I can dual-feed the block. I'm going to be selling them, as well. It's actually a pretty simple setup. It does require a remote thermostat, though. The setup is pricey...about $800 all-in.
shoebox,
I've used your site numerous times. If you want, I'll send you a write-up on how I did this. I guess I'll hit Pick-A-Part and yank an alternator bracket off an 80s Camaro so I can see if it's long or short and then go from there.
Thanks for the help.
Old Feb 3, 2010 | 10:26 AM
Z28SORR's Avatar
Do these plates maintain the "reverse flow" unique to the LT1's?
Old Feb 3, 2010 | 11:47 AM
Colin's Avatar
Yes, they do. I'm using a dual-outlet Meziere 55gph electric water pump. I am dual-feeding the block and then the coolant leaves each side and joins in a remote thermostat housing. From there, I have a single 1.5" conventional hose into my radiator.
I had to run this setup because I can't run standard small block engine mounts in my application. I am using front engine mounts that prevent me from using the serpentine system. If you're interested, it's the Hooker V8 Vega kit.
Old Feb 3, 2010 | 12:47 PM
RamAir95TA's Avatar
Sounds like a neat setup! I'd love to see it.
parkers Z28
Mar 11, 2016 08:14 PM
LT14LIFE
Feb 9, 2015 09:35 PM
CARiD
Jan 14, 2015 04:00 AM
Decromin
Aug 18, 2002 10:11 AM
