lt1 water pump gear shaft???
i am sure this has been discussed at some point so lets see some of those answers
i am currently dealing with this similar decision as this guy
http://forums.chevyhiperformance.com...ars/index.html
here is what i want to do though.
since i have an electric water pump i do not have a need for the water pump shaft that comes out of the timing cover of my 96 lt1.. i wish to just remove the shaft/gear assemble all together and not reinstall it. weld up the timing cover hole and that is it.
what i am wanting to make sure of since i can not seem to find this info nor have i had it off yet to see. is there anything else that the water pump shaft operates besides just the water pump and is it connected to anything else. i have the 2 torque bolts off and i am told i just have to use a lot of force to pop it out.
but will it cause any problems if it isn't reinstalled? meaning i assume there will be a hole where the water pump shaft used to be. and then just weld up the timing cover.
Your link is bad.
To answer your question, yes the WP drive shaft only operates the WP, so removing will affect nothing else. You are supposed to use a special puller to remove the gear though. But I would recommend a brass plug for the cover as opposed to welding, just in case you change your mind later. My $0.02.
Carolina,
The oil that accumulates in the valley area is not under pressure so there is no starvation issue. It is primarily oil that has drained back from the heads, just looking for a way to get back to the pan. Actually, the more quickly it can return to the pan, preferably without dribbling down through the rotating assembly, the better. There is no pressurized oil delivery to the water pump drive itself.
Carolina,
Also, when removing the water pump's drive with the intake on, I attatch a Vice Grip to the pump's drive and tap it out with a hammer.
