Can 96 z28 car retard with no check engine light?
Old Aug 6, 2008 | 06:44 PM
djm_e22's Avatar
Can 96 z28 retard with no check engine light? Also does autozone scanner check this? Thanks for any help.
Old Aug 7, 2008 | 05:25 AM
Knock retard does not set a code or cause an SES light. Its generally not due to an engine problem, its due to using the wrong fuel, in most instances. You need a scanner (not a code puller) to monitor knock retard.
If, on the other hand, your knock sensor or wiring is faulty, it will set a code, you will get an SES light, and the PCM will respond by applying knock retard ranging up to 15 degrees, depending on engine operating conditions.
bfmv13trivium
Jan 14, 2015 09:57 AM
ro2207
Dec 4, 2014 06:18 PM
mspennyhughes
Nov 28, 2014 03:22 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
