LT1 Video Spun Bearing
Old Dec 25, 2005 | 03:30 PM
  #16
kirschman's Avatar
Re: LT1 Video Spun Bearing
Originally Posted by ChevyTuffD.A.
Just a question. When u get that squeeking noise does it always mean spun bearing?? Right after I got done with my cam install I had that same noise but it sounded like it was coming from the DS valve cover. We pulled the cover and it went away right after that and it hasnt come back since, maybe 2k miles since cam install. My oil pressure is still good as always and I dont seem to be down on power after that.
Did you clearance the v/c's for the rockers? I had to do alittle "bending" on the center bolt bracket to get it to clear the rockers. Mine where the n/sa type, not sure if the type you got will give you the same prob. Pull the cover off and look to see if it was rubbing anywhere.
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
