LT1 Valve Lash Question
Old May 22, 2003 | 07:44 AM
Paul94Z28's Avatar
So, I had my valve lash professionally set with my 1.6 roller rockers last year. They are the GM ones with the adjustable nuts.
I removed them with a socket wrench and did not mess with the adjusting nuts. I kept the rocker arms, pushrods, and nuts organized by cylinder. I swapped the stock cam out for a hotcam.
Lets say if I were to re-assemble everything, and just tighten down the rockers on all cylinders to the adjusting nut stop.
My assumption would be one of two things.
1) Everything will be just fine and within acceptable tolerances for lash.
2) It will be too tight and require adjusting for the different profile of the cam
What do you think? I know the manual says use the TDC method. Am I thinking about this too much, or should I just suck it up and follow the manual?
Thanks in advance for your opinions.
Paul
Old May 22, 2003 | 07:51 AM
Any time the nuts are removed, you will have to re-adjust the preload. This includes backing off the lock screws, adjusting, then re-tightening the locks.
Old May 22, 2003 | 10:16 AM
quicksilver97ta's Avatar
Theres no guarantee the base circle on the cam lobes (which is where the valves will be closed) will be the same with a different cam, even if its GM.
Old May 22, 2003 | 12:41 PM
Paul94Z28's Avatar
Base Circle
I guess that is where my thinking was flawed. I was thinking that the base circle was the same on the two cams and that the settings would be the same (as long as I kept the hardware on the same cylinders).
Looks like I will be following one of shoebox's methods prior to coughing up the money to have it done.
Thanks for the assistance.
Old May 22, 2003 | 01:34 PM
joeSS97's Avatar
Paul you can do it.Not hard at all,once you know how.Heck I could help you for free. Save your money.
Old May 22, 2003 | 01:48 PM
tsleg's Avatar
Base crcle on cam lobes is definitely different between the stock cam and the hotcam. Hotcam base is smaller.
Old May 22, 2003 | 03:29 PM
Paul94Z28's Avatar
Hey Joe
Joe-
I sent you mail with the plan.
Let me know if it sounds right.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 29, 2014 04:54 PM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
