LT1 tuning
LT1 tuning
Kindof still a newb to the LT1 scene, will be sporting an Lt1 and 6 speed in my '88 in a couple months. just wondering of what options do I have to go about tuning this bad boy...what kind of tuining software is out there for the Lt1's?
Re: LT1 tuning
It all depends on what year computer you are using!
93 uses chips that are replaceable
94-95 Non California cars are OBD-I and can be tuned by tunercat and LT1 Edit
96-97 and some 95 California cars are OBD-II and they only have LT1 Edit available at this time, that I am aware of but I have been out of the tuning setion for a while, check into that section for more detailed info!
Re: LT1 tuning
Re: LT1 tuning
Originally Posted by Red96Lt1
It's cheaper and easier to send it to www.madz28.com and have them do it for you
If you're using a '94 or '95 PCM, check out www.tunercat.com. Their software is dirt cheap and easy to use.
Re: LT1 tuning
Originally Posted by BadIroc
its a '94 car so it would be obd-1....anyone have any good luck with the tunercats? I've heard of LT1 edit before but I don't know anyone personally who has used it before. Like I said this is all new to me, but can't wait till this thing is finished
Re: LT1 tuning
How exactly does a 'mail order tune' work? Does the tuner send you the .bin file via email and you have to flash the PCM yourself? If this is te case, I take it you have to have an editing program whether it's TunerCat or LT1 Edit, and an interface cable.
And the other way is just to send the actual PCM to a tuner, correct?
I would really like to learn to tune my PCM myself so I can properly dyno tune it, what is the best way to get started? What I plan on doing is having a professional tuner make me a file to my specs, but then I can fine tune it on the dyno.
Re: LT1 tuning
The reason the email tunes are so inexpensive is because there is no real overhead with them, mail charges, rigs to power the PCM on to flash it, and stuff like that! Yes you will need to buy a cable, and that is a good investment to monitoring the stats of the engine also.. You don't need a full version of tunercat or LT1 edit to flash the PCM, all you need is a flash utility that in most cases are supplied by the tuner.
I started by getting a copy of tunercat and looking at the tables and learning what they all did, the web is a good source for finding this info... Then when I knew what the different tables did I started playing with it, I would find files online from different combinations and reading those tables I pulled out what I thought would work well for me. Until you get good and have done it for a while it is all trial and error. I remeber testing out how to modify the shift Rpm's one time and when I took the car out to test it it didn't shift out of First gear!
I was soo scared that I messed something up, then I remebered I kept all of the previous test tunes, so I just went back and reloaded the previous tune and everything was fine.. Like I said trial and error, just get something to log what the car is doing or you might get into trouble quick! Oh and don't change something and jump right into WOT testing! Unless you know what you did isn't going to kill the motor..Search the web for freescan, that is free software that can be used to scan the car and also give a log of what is going on.
Re: LT1 tuning
I really appreciate all the info you gave me to get started in the right direction. What do you mean by 'log' what the car is doing? Is it like real time statis of the PCM while you are driving the car? I'm not too clear on that part.
Re: LT1 tuning
Re: LT1 tuning
I got tunercat for my 91 LT1. I love it. I tune it myself and can do it whenever I want. Plus it's cheap so if I need to get it pro tuned in a case like cam/heads, I won't feel bad about paying someone else to do it. Tunercat is right at 90 bucks as opposed to LT1 edit(which was 500 when I was looking at it).
Re: LT1 tuning
I also use tunercat. Its simple enough to use as long as you know what to adjust. But then again thats all part of the learning process. But there in an inexhuastable amount of help here
