lt1 timing chane
Old Mar 20, 2006 | 09:15 PM
pat35's Avatar
lt1 timing chane
with a 95 lt1 when you take it to a double roller do you use the l98 set up gear chain cam gear?just want to make sure i order the right parts.
thanks pat
Old Mar 20, 2006 | 09:42 PM
3gc's Avatar
3gc
Re: lt1 timing chane
I'm pretty sure you just use a regular SBC chain. I used Comp cams 3136 Double roller on my motor. When you install it, be sure you clearance the timing cover plenty before running the motor. I had to tear mine apart again because the cam gear rubbed the cover ever so slightly.
Old Mar 20, 2006 | 10:13 PM
pat35's Avatar
was told i need a l98 chane.
1quickTA's Avatar
How could you tell that it was rubbing "slightly"? Just heard it scraping or what?
Old Mar 21, 2006 | 06:35 AM
pat35's Avatar
any mor
Old Mar 21, 2006 | 02:26 PM
3gc's Avatar
3gc
Yeah it made a noise when it was rubbing. When I took the timing cover off it had a few shallow scratches where it was rubbing. It looked like the raised lettering for the part number on the cam gear was rubbing a bit. Hopefully no harm was done. I didn't find a lot of metal in the pan or the oil.
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
GhostZ28
Dec 7, 2014 11:53 PM
blac94Z
Nov 24, 2014 07:12 PM
