LT1 Timing chain Replacement
Old Oct 1, 2005 | 10:17 AM
Cepan's Avatar
HOw long does GM recommend you keep the stock timing cahin in a 1997 LT1 engine?
PLease dont say LIFETIME......
Realistically when should it be replaced???
any suggestions on a good brand to replace it with?
Old Oct 1, 2005 | 12:37 PM
crazypurgatory's Avatar
Lightbulb Re: LT1 Timing chain Replacement
Not sure that GM has a recommendation on that.
But I would say it should be good for one hundred thousand miles.
It all depends on how much abuse it has had too.
By then it should be getting some slack in it.
Chris G.
Old Oct 1, 2005 | 01:57 PM
It's not a Honda with a drive belt. There really is not any recommendations on changing the timing chain. Obviously, any high mileage engine that is already torn down for engine work should have the timing set changed.
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
ScottZ
Mar 3, 2004 01:34 PM
1LEThumper
Jul 14, 2003 12:45 PM
GigaMp3z
Feb 20, 2003 02:57 PM
