lt1 timing chain
Old Jun 23, 2004 | 09:49 PM
lt1g3n's Avatar
lt1 timing chain
should there be any slack at all on the timing chain? Mine seems to have a bit of slack, i canactually push it from either side and itw ill move in a little bit, is that bad ? The chain is all the way on the cam and crank sprocket, bad chain? Weird thing is the chain is "new" came with my motor assembled new
Old Jun 23, 2004 | 10:19 PM
IrocSS85's Avatar
yeah, they all have some slack. in a stock chain, it will seem like alot of play. but thats normal.
Old Jun 24, 2004 | 01:19 AM
lt1g3n's Avatar
sweet thanks, also you wouldnt happen to know about those two metal peices that run along each side of the oil pan that go before bolting it, well, i accidently forgot to put those back on after doing all the work of liftin the motor a bit and replacing the oil pan gasket then i just bolted it back up , and theres a lotof bolts down there i was like aww **** :/ .. should i re do it and put them on or would it be even worse if i did that since im sure that helps form the pan so it doesnt "bend" a bit..
thanks either way man
Old Jun 24, 2004 | 06:04 AM
IrocSS85's Avatar
yeah, you need them. the oil pan will most certainly leak w/o them. they distribute the load across the surface to better clamp down. sorry
Old Jun 24, 2004 | 03:30 PM
lt1g3n's Avatar
ah well, no biggie, doesnt take that long , better to do it right thanks again
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
