lt1 Ticking.
Old Jun 11, 2007 | 08:30 PM
Andy SS Z28's Avatar
lt1 Ticking.
Had heads off for head gasket replacement. after putting engine back together, engine ran fine, except for a slight ticking. Very hard to notice, I did not hear it right away but it sounded like a slightly loose valve. I only noticed it after I returned from a test drive. Let car set for a week, had no time to look into the ticking. went out and started car on saturday and the ticking had some how gotten way more noticeable. It was coming from under ds valve cover. pulled cover and found #7 intake rocker very loose. But the nut on the rocker stud seemed to be about the same height as all the others. Note: stock every thing. Any thoughts.
Old Jun 11, 2007 | 08:38 PM
CK9192004's Avatar
I have pretty much the same problem. I had a tech from the dealership I work at listen. Apparently there was a bulletin out about these engines that both LT1 and LS1 have slight piston slap, and that it was nothing to be of a concern.
I still believe its a lifter or somethin
Old Jun 11, 2007 | 08:46 PM
ricehammer's Avatar
Sounds like your #7 intake lifter is not staying pumped up or the valve lash has come out of adjustment.
Old Jun 11, 2007 | 09:24 PM
Severous01's Avatar
agree
reset lash and if this happens again, replace lifters...or at least that one.
Old Jun 11, 2007 | 09:44 PM
if a lifter bleeds down, won't it pump back up after it gets oil pressure? And how long should it take to do it if it will pump back up?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
