lt1 thermo
Old Nov 24, 2003 | 12:24 PM
blazzinbird's Avatar
lt1 thermo
heyis there a cetian way that it has to fit in the housing, i mean turned wise. i have no heat and i wonser if is turned the wronge way
Old Nov 24, 2003 | 12:27 PM
Always look at Shoebox's Tech Pages for questions like this.
Old Nov 24, 2003 | 12:31 PM
been there, it showes the top part of the thrmo sitting at a angle, but mine is sittinf strait up and down, i just want to know whos elses is like that
Old Nov 24, 2003 | 12:32 PM
You mean the way the top "bars" are aligned? It doesn't make any difference.
Old Nov 24, 2003 | 12:39 PM
hummm i guess i am going to take the heater hoses off and clean them, unless my thermo is bad, cause i had heat befor i put my 160 in, then i had to heat once winter got here, so a few days ago i put the stocker back in, and still no heat. So eaither bad thermo or, clocged heater hoses
Old Nov 24, 2003 | 01:09 PM
F Carline 94's Avatar
on a side note,
Everytime the thermostat housing comes up, I want to remind everyone DO NOT use the GM service manual (1994) torque specs on the thermo housing bolts. 21 lb-ft can't be right and probably will break them.
anybody know the correct value BTW?
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
99TransAmWS6
Sep 10, 2002 09:04 PM
99TransAmWS6
Sep 2, 2002 11:41 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Skull Leader
Aug 10, 2002 11:01 AM
