Lt1 swap
Old Oct 30, 2010 | 10:24 AM
***REM***'s Avatar
Lt1 swap
Help i dont know what i got myself into and need help i have a 71 nova and would like to swap a lt1 motor into her. I have a complete running 94 caprice police pakage with a lt1 motor how hard is this swap? Ive been told its not easy and that i would need to buy headers, harness, new mounts has anyone done this swap in a nova? What do i need to get to do this swap can i use the stock hareness do i need to do any mods to it plz any help would b greatly appriciated thx. Also since im at it would also like to add a lite mod cam to it, i dont plan on racing but deff would like the extra kick. This also will be mostly my every day car thx for ur help
Old Oct 30, 2010 | 11:21 AM
Are you going to keep the electronic fuel injection, and Optispark distributor, or are you going to convert to a carb with conventional rear-mounted distributor?
The Caprice LT1 has iron heads and milder cam - F-Body and Y-Bodys have aluminum heads and a bit more aggressive cam. Just from a weight advantage, the aluminum heads might be worth installing.
Old Dec 31, 2010 | 01:32 AM
SCNGENNFTHGEN's Avatar
Thumbs up Re: Lt1 swap
Man the Nova swap should be cake. Like my 68 Camaro essentially. Wish I could find something like that quick and cheap I could throw mt LT1 into. My swap was in the 90 Silverado in my sig, which I've since passed on to my little brother. The trans went out, then it blew a head gasket. We had the valves done, and cleaned up the heads. The trans is being fixed. He has a hot cam kit coming, and then we'll screw it all back together, it should be pretty sick. It was a handfull before with no cam. Once we get it all done the ecm is getting a tune for the rear. That was my mistake. Hey I couldn't think of everything, so if you use the 4l60e make sure you have the ecm tuned for your rear end ratio. My shift points were a little off going from a 3:23.1- a 3:07.1 in the truck. Outside of that, it worked out great, and I drove it around for quite a while. I was trying to use a hypertech to get them right, and they got better, but what killed my trans was loading it up and driving down south pulling a trailer. Next swap I have no intention of using an automatic trans. I'm looking to do it again only this time with my Tremec (pulled from my 68) bolted to it, into something without an ecm, as I happened to get my hands on a GMPP LT1 carb intake and a MSD streetfire distributor. Injuneer probably knows more on the swap subject, just figured I'd give my .02. There a few things to hook up if you're running it with an ecm. It's not really that bad though, and mpg will be into a neighborhood that Nova has probably never seen.
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
