97 z28 problems...need help
Old Dec 25, 2010 | 02:17 AM
remy2435's Avatar
well its been a long time...but im in need of help and knew this was the best place to turn....i already know my starter is shot and in need of a new battery..... my z28 has 123k on it and its running very poorly...ses is on. i assume a tuneup..
i know its not alot opf info but nething will help
Old Dec 25, 2010 | 02:30 AM
RamAir95TA's Avatar
Re: 97 z28 problems...need help
No use in speculating...the SES light is on for a reason. You should have it scanned to give you a good place to start.
Old Dec 25, 2010 | 02:39 PM
oneclean97z's Avatar
agreed. scan it at autozone for what code the ses is throwing. i recently had the most common one, the random cylinder misfire. ended up being a few old/useless plugs and one spark plug wire that was worn down from rubbing against something and started grounding/arching out to something. got new plugs and wires and all is well. their not cheap or fun to do on these LT1's tho : /
Old Dec 25, 2010 | 05:25 PM
When you have it scanned, get the EXACT numercial code(s). The generic list of code interpretations that you get at most places are not as useful as looking the codes up on an LT1-specific list. They'll tell you something like "it's an O2 sensor code", and unless you have the specific code, you won't know any more than when you started.
Old Dec 31, 2010 | 01:46 AM
remy2435's Avatar
well i know a tuneup is in order...i need to get it to start before i can get it to a store...unless someone close has one that they could bring over and allow my use which for i would reimburse...but i have a starter enroute and i need to know what all parts i need to perform a tuneup apart from an air and fuel filter. and where the best place to purchase would be...thanks for all the help in advance
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
