Lt1 stumbles and hesitant
Old Jul 15, 2008 | 07:47 PM
  #31
86Camarolt1's Avatar
well my injectors were leaking so I replaced them and why not replace the fpr since it was old and I was taking the fuel rail off anyway.thats how I see it. so it has to be something else
Old Jul 15, 2008 | 10:32 PM
  #32
tlillard23's Avatar
Cool. did you pull the injectors to see if they are working?
(I just changed a bunch of stuff and am chasing my **** too...)
Old Jul 16, 2008 | 02:03 AM
  #33
LJM97Z's Avatar
What did you use for the feed line in the tank on your Walbro pump?
Old Jul 16, 2008 | 07:01 AM
  #34
yea I mad sure injectors are working. Im using the factory feed/return lines and the factory pump diaphram with a new Walbro pump in my 86
Old Jul 16, 2008 | 08:04 AM
  #35
hosspwr94's Avatar
opti or maf!
its a pain but the opti could have thrown off the rotor! This happened to my brand new MSD a few months back! If you can get a hold of another maf try switching those out first.
Old Jul 16, 2008 | 12:27 PM
  #36
MarcR94v6's Avatar
not to hijack, but how do you check the injectors themselves?
Old Jul 16, 2008 | 05:52 PM
  #37
when you gently pull off your fuel rail,turn the key just so it primes(do not start engine) and you will now if they are leaking. I hope it is the MAF causing my problem, this is one of few sensors I did not replace.My opti is a new AC Delco unit also.
Old Jul 17, 2008 | 07:53 PM
  #38
Leem927's Avatar
for a year and some i have ran my car with out 02s. i hooked them up recently and now sometimes under load it back fires stumbles puts lots of wierd stuff. i get a code saying my maf is bad. switched it out and it still says its bad. i dunno. i want to sayits the opti but somtimes it still runs good. maybe our cars just dont like us. but im sure if i unplugged the 02 sensors the problem will go away.
Old Jul 21, 2008 | 02:05 AM
  #39
tlillard23's Avatar
86Camarolt1: did you ever figure this out?
Old Jul 21, 2008 | 07:11 AM
  #40
yea it was the MAF. but now my fuel pump is taking a **** on me. has anyone replaced their fuel pump from inside rear of the car instead of dropping the tank
Brake_L8
Jan 20, 2015 09:44 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
Dave19yz28
Jan 26, 2003 01:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
