coil location?
Old Jul 20, 2008 | 10:17 PM
Bluovlh8er's Avatar
coil location?
i need to know where the coil or ignition coil module is located on a 95 z28...
Old Jul 20, 2008 | 10:28 PM
96' Formula WS6's Avatar
The coil and ICM are attahced to eachother by a bracket. On my 94 it is bolted on the driver side head.
Old Jul 20, 2008 | 10:32 PM
Bluovlh8er's Avatar
i am tring to wire up a shift light... they said i need to run a green wire to the - side of the coil...
Old Jul 20, 2008 | 11:26 PM
You can easily wire a shift light and stay inside the car by wiring it to C230, cavity D, white wire. The white wire goes to the red PCM connector pin 13 (tach signal).
Old Jul 21, 2008 | 07:44 AM
seawolf06's Avatar
Wire it to the pcm, not the coil.
RUENUF
Mar 13, 2016 03:39 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
bsmith
Jul 19, 2002 06:08 PM
