LT1 Stock Compression Ratio?
Old Jun 12, 2005 | 01:18 PM
ChrisUlrich's Avatar
I read thats it 10.4 - 1... but a dude at a machine shop told me our cars really run at 9 1/2 - 1 because the PCM retards everything.
Because I want to run my car at 11 - 1 because I want to spray... but he is saying that I can't run my car at anything more 9 1/2 - 1 because anything more then that can't use 94 octane. Is this true?
Old Jun 12, 2005 | 01:21 PM
Cman's Avatar
Re: LT1 Stock Compression Ratio?
Stk LT1 F-body CR is 10.5:1
Your dude at the machine shop needs to stop smoking the good stuff and brush up on his Gen 2 SBC specs.
Tony
Old Jun 12, 2005 | 01:26 PM
Addtionally, its not static compression ratio that determines the octane requirements... it "dynamic compression ratio" (DCR). DCR reflects your cam specs.
Old Jun 12, 2005 | 01:49 PM
MachinistOne's Avatar
The PCM retards everything? huh? Compression is set in stone....yeah - it is 10.4:1
11:1 with a cam around 270/280 and some chamber smoothing will not detonate.
Old Jun 12, 2005 | 09:02 PM
Well i'm gonna have a LE2 setup for a 383 stroker... want a 11 to 1 cr but the dude told me that I can't run pump gas with that setup... sounds a little funny to me. Says that the timing is retarded to stop pre-detonation...
So this dude is just full of it?
Old Jun 12, 2005 | 09:22 PM
1racerdude's Avatar
He don't know what he is talking about.
Our shop car is 12.98 on pump gas with a 9.2DCR.If ya give me your engine details and cam ADV numbers I will figure it up for ya.
That 270/280 figure has got to be ADV duration
Old Jun 12, 2005 | 10:29 PM
89385formula's Avatar
So is this guy the one doing your machine work? It may not affect his machining ability, but I would still take my engine somewhere else. Sounds like this guy doesn't have a clue.
oldschool
Feb 9, 2016 09:21 PM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
Rich_z28
Aug 27, 2002 12:20 AM
