Lt1 stage 1 cam supporting mods needed?
So my 96 z28 I was having problems with, turns out 4 bent rods.. Replaced those she runs good.my mechanic buddy wants to put a stage 1 cam in it for me and I'm wondering if I need anything to go along with it. Will there be any problems it's just a street cam maybe the corvette cam. Thanks!
Re: Lt1 stage 1 cam supporting mods needed?
What are the specs on the "stage 1" cam? That's not a common term with regard to the LT1 that I am familiar with.
You need a good cold air intake and a good catback exhaust as a minimum before thinking about a cam.
After years on the forums I can confidently say the many problems start with "my friend who is a mechanic".
All I can say is educate yourself. The problem with the performance world and maybe the country in general is people are too busy playing candy crush and not busy enough seeking knowledge and truth. Taking someones else's word for it is an easy way to become somebody's fool.
That being said, if he's using the term "stage 1 cam" it's safe to say he can't point you in the right direction. Do some research here. You'll find that a cam worth swapping in there needs to be in the 215-220 @.050" intake duration range to be worth it in my eyes. Good search terms would be CC305, Hotcam, XE503, CC503, GM846.
Stealth Formula posted this on another website that could help establish a base of information to build on. This is not the gospel, but it'll help build a knowledge structure.
"Intro:
It seems like several people every week want to know what cam is best for their LT1 powered car or what components they need to perform a cam swap. This guide focuses on the most common and proven camshafts available for LT1’s as well as the most common and proven valve train components. The majority of focus is on LT1 cars running stock bottom ends and stock heads however it still will offer some insight to those who have built bottom ends and head work. I encourage you to read the entire guide and hopefully you may learn something and allow yourself to select the perfect cam and valve train components for your particular setup.
Part 1: Choosing A Camshaft:
-Bigger is NOT always better.
-Sound does NOT equal power.
-Before selecting a cam you must develop your needs/wants/plans for your car, as that is what should determine which camshaft you select.
-A very basic understanding of a camshaft below; to better understand what the duration, lift, and lobe separation of a camshaft means, give this thread a look:
*** Cam Guide *** - LS1TECH
Ex: Stock 1997 F-Body Camshaft Specs: (200/207 .447/.459 117 LSA)
Duration: Duration is the time that the valve is open. Increasing the duration keeps the valves open longer which increases top-end power therefore raising the power band.
Lift: Lift is the maximum amount in inches that the valves are open. Increasing lift equals more horsepower and torque but at the same time can lead to more peaky torque curves.
Lobe Separation: Lobes Separation Angle (LSA) is the number of degrees the intake and exhaust lobes are separated. The lower the LSA is, the more overlap you have. Increasing overlap leads to increased top-end power while reducing low-speed power and idle quality.
-If you are in the market for a camshaft purely for sound and are willing to sacrifice usable power and drivability then something along the lines of the cc306 or GM847 will suite you well. However, if you want the full potential out of these cams you will need to be shifting at 6400+ rpm which is VERY risky on the stock bottom end. Some have been lucky while others have not but a stock block typically will not last long if being shifted at or above 6400/6500rpm. Just because camshafts as large as the cc306, GM847, etc. make more peak power, doesn't mean the car is faster. The key is usable power which is the power under the curve and you want a cam that fits in the usable power range that YOU want. Camshafts that large, lack low-end power because their power bands are more geared towards higher rpm's. Also, the worst thing you can do is run a cam of any sorts and not rev it to where it wants to be. Not revving a car out to where it wants to be will result in poor track times for your setup. An example below…
(Ex: I once ran the cc503 in my LT1 and shifted it at the stock shift point which is lower than desired for that particular cam. When I bumped the shifts up to where they wanted to be (6300ish) I picked up .4 and 4 mph in the quarter mile. If say I wasn’t willing to rev past 6000rpm, that cc503 would be hindering me. In that case I would be better off running a much smaller cam like the LPE 211/219 or something along those lines.)
***Now...I do not want you to think that the Comp 230/236, cc306, or GM847 etc. etc. are bad camshafts because they are not. Those cams have been proven for years to make great power and perform great at the track. Because of their large durations I like to use them as examples to prove points well. For some they may be the perfect camshaft choice but for most there tends to be better alternatives with a stock block/headed LT1, just depends what YOU want from the car. If you’re willing to rev the car out to where it’s deemed rather unsafe on the stock bottom end and your primary goal is to run the fastest ET’s possible then by all means they would be excellent choices. Unfortunately stock LT1 heads do not let these cams to be used to their full potential. Those with built bottom ends and head work greatly benefit from the use of these cams.***
-If you error on choosing a cam too small, you will still enjoy driving the car more than you did while it was stock and will be motivated to go a little bigger next time around. If you error on choosing a cam too large, it will more than likely hurt your enjoyment of driving the car compared to stock so the proper camshaft selection is very important.
-Below are some of the most popular and proven off the-shelf camshafts that will work great with LTx’s while performing well on the street and on the track. Also listed is the option to go the Custom Grind route. With today’s technology and the expertise and knowledge of certain individuals/companies, going with a custom grind is many times the best overall option.
***Keep in mind, the advertised rpm range of a particular cam given by the manufacturer is not necessarily 100% accurate and most cases it is not! Remember that the next time your looking through a catalog or on a website at a cam that you like.***
Custom Grind:
Pros: The optimal choice for the most power and best drivability because the camshaft is ground specifically for your setup and what you want out of the car.
Cons: Cost a little more than an off the-shelf camshaft (another $50-100 or so). If you change your setup down the road, the custom cam may not work to its potential on your new setup.
Pass Emissions?: Yes or No it’s up to you.
Shift Point for Maximum Performance: Wherever you are willing to rev it to.
Idle Characteristics: Whatever your looking for, from sleeper to choppy.
M6; Require Gears?: On a manual car, gearing plays a big part in cam size.
A4; Require Stall?: On an auto car, more stall is needed for larger cams but a custom camshaft can be designed around your existing or planned stall size.
Where can I get a Custom Grind?: A few places offer custom grinds with the most popular in the LTx crowd being Lloyd Elliott and Advanced Induction. Other good choices are Ed Curtis and Cam Motions.
Comp Cams:
cc502: (218/224 .528/.537 112lsa) w/ 1.6RR's
Features Comp's relatively newer technology XE (Xtreme Energy) lobes for more top-end power. Exhibits great drivability with a strong mid-range and moderately good top-end. Similar to the LT4 “Hot Cam” in performance and drivability.
Shift Point for Maximum Performance: 6100-6200rpm
Idle Characteristics: Moderately Choppy Idle
M6; Require Gears?: No
A4; Require Stall?: 2500+ Stall Speed
XFI 466: (218/224 .570/.565 113lsa) w/ 1.6RR's
A newer grind from Comp Cams. It utilizes their very aggressive XFI (Xtreme Fuel Injection) lobes that are good for increased power over older technology lobes like Magnum etc. Along with excellent drivability it exhibits a very strong mid-range with a good low-end and moderately strong top-end. Essentially a beefed up LT4 “Hot Cam” and cc502. With its 113lsa it takes a more trained ear to know that it’s there making it a decent “sleeper” cam. Note: Due to its very aggressive lobe design, requires the use of “Beehive” valve springs.
Idle Characteristics: Smooth Idle
cc305: (220/230 .544/.544 114lsa) w/ 1.6RR's
Features Comp’s Magnum lobes with are older technology but proven not to take a beating on valve train components. Comes in a 112lsa and 114lsa. The 112lsa will have slightly more top-end power over the 114lsa which will have slightly more low-end power. The 114lsa is sometimes favored by cars running Nitrous or Blowers because it provides less overlap than the 112lsa. The less overlap leads to more potential power from the Nitrous/Blower. In the case of Nitrous your typical 75-150 shot will not really benefit from the 114lsa over the 112lsa, different when the shot increases beyond that however. Pretty comparable to the LT4 “Hot Cam” in terms of power with the cc503/GM846 a step ahead.
Shift Point for Maximum Performance: 6200-6300rpm
Idle Characteristics: 114lsa will have a Smooth Idle, 112lsa will have a more Choppy Idle
cc503: (224/230 .537/.544 112lsa) w/ 1.6RR's
Widely known for being the biggest cam you want to run on a stock headed car without sacrificing usable power and drivability. Features Comp’s relatively newer XE (Xtreme Energy) lobes for increased top-end power. Has a very strong mid-range with strong top-end power without much if any loss in the low-end. Similar to the GM846 and good for a solid 10-15hp/tq throughout over the “Hot Cam”, cc305 etc. May have some cam surge, depends how good the tune is.
Pass Emissions?: No, requires tuning to pass
Shift Point for Maximum Performance: 6200-6400rpm
Idle Characteristics: Choppy Idle
XE 230/236: (230/236 .544/.555 112lsa) w/ 1.6RR's
Features Comp’s relatively newer XE (Xtreme Energy) lobes for increased top-end power. An excellent selection for the individual stuck between the cc503 and the cc306 or the GM846 and GM847 etc. Because of its more aggressive lobe design it will perform similar to its larger cc306 cousin while exhibiting slightly better drivability. Expect a very strong mid-range and top-end with some loss in the low-end. The beginning of pushing it with a stock bottom end and more recommend for cars that aren’t daily drivers. Works very well in cars with built bottom ends and head work. Automatics require high-stall converters and gears and 6-speeds require steep gearing to run this cam successfully. May have some cam surge, depends how good the tune is as well as stall size/gearing.
Pass Emissions?: No
Shift Point for Maximum Performance: 6400+rpm
M6; Require Gears?: Yes
A4; Require Stall?: 2800+ Stall Speed
cc306: (230/244 .544/.576 112lsa) w/ 1.6RR's
Features Comp’s Magnum lobes with are older technology but proven not to take a beating on valve train components. Has been proven over the years to make good numbers and perform well at the track. Similar in power output with the newer XE 230/236 with slightly worse drivability. Exhibits a very strong mid-range and top-end with some low-end loss. Not recommended for cars that are daily drivers or that have stock bottom ends/heads due to its large size in duration. Stock heads don’t allow this cam to be used to its full potential so one with a built bottom end and head work would benefit greatly from this cam. Automatics require high-stall converters and gears and 6-speeds require steep gearing to run this cam successfully. Degree of cam surge will be determined by how good the tune is, stall size/gearing etc.
Pass Emissions?: No
Idle Characteristics: Very Choppy Idle
Crane Cams:
Crane 227: (210/224 .511/.553 112lsa) w/1.6RR's
Good proven performer on stock heads. Stock LT1 heads have restrictive exhaust ports relative to the intake ports and the 227's wide split in duration helps balance that out. The 227's low-end power starts low and is consistent through the entire mid-range making it a popular choice among guys with heavy B-Bodies. Will have stock like drivability and is known to be a torque monster. Lope is not very noticeable making it a nice “sleeper” cam.
Shift Point for Maximum Performance: 6000-6200rpm
Idle Characteristics: Smooth Idle with a Slight Lope
GMPP:
LT4 “Hot Cam”: (218/228 .525/.525 112lsa) w/ 1.6RR's
An older technology design that has proven itself in reliability and decent power output. Exhibits great drivability with a nice mid-range, step up from the factory LT4 camshaft hence the "Hot" in LT4 "Hot Cam". A good selection for the person who doesn’t want to do research or have the best cam out there due to the ease of purchasing the entire kit. Similar to the cc502 and cc305 with the XFI 466 having a decent edge on it and the GM846/cc503 putting out another 10-15hp/tq throughout with similar drivability.
Shift Point for Maximum Performance: 6100-6300rpm
Idle Characteristics: Slightly Choppy Idle
GM846: (222/230 .543/.563 112lsa) w/ 1.6RR's
Right there with the cc503 in terms of being widely known for the largest cam you want to run on stock heads and retain good drivability and usable power. Has a very strong mid-range and good top-end power without much if any loss in the low-end. Similar to the cc503 and good for a solid 10-15hp/tq throughout over the “Hot Cam”, cc305 etc. May have some cam surge, depends how good the tune is.
A4; Require Stall?: 2500+ Stall Speed"
continued below....
"Intro:
Custom Grind:
Comp Cams:
Pass Emissions?: No
Pass Emissions?: No
Crane Cams:
GMPP:
continued below....
GM847: (234/242 .575/.595 112lsa) w/ 1.6RR's
The largest cam of the bunch. Over the years it has proven itself as a cam that puts out good numbers and good track times. Very strong mid-range and top-end with some low-end loss. Will put out slightly better numbers than the cc306 while exhibiting similar drivability. Not recommended for cars that are daily drivers or that have stock bottom ends/heads due to its large size in duration. Stock heads don’t allow this cam to be used to its full potential so one with a built bottom end and head work would benefit greatly from this cam. Automatics require high-stall converters and gears and 6-speeds require steep gearing to run this cam successfully. Degree of cam surge will be determined by how good the tune is, stall size/gearing etc.
Pass Emissions?: No
Lingenfelter Performance Engineering:
LPE 211/219: (211/219 .530/.560 112lsa) w/ 1.6RR's
Has stock-like drivability and known to have instant torque in the low rpm's. Very comparable to the Crane 227 with its low rpm power that comes in early and is consistent throughout the mid-range. Lope is not very noticeable making it a nice “sleeper” cam.
Shift Point for Maximum Performance: 6000-6100rpm
A4; Require Stall?: 2600+ Stall Speed
Pass Emissions?: No
Part 2: The Components Needed For A Cam Swap
The following are the recommended/required components needed for doing a cam swap. The valve train is not a good place to cut corners with. In terms of doing the valve train it is recommended to do it right the first time, so it can all be done one time and one time only.
A. Valve Springs:
Purpose: Keep the valve in control.
Benefit of Upgrading: Upgrading the valve springs is ABSOLUTELY mandatory in doing a cam swap. The stock valve springs CANNOT handle any more lift or RPM than the stock cam puts out as well as a cam with a more aggressive lobe design.
Required: YES.
Popular Choices: Crane Dual Spring Kit 10308-1 (includes locks, retainers, shims), PAC Beehives 1218 or Comp Cams Beehives 26918.
Note: Make sure the valve springs you purchase are matched to the camshaft you plan to run. You do not want the valve springs to go into coil bind which is maximum compression of the spring till its solid because this will cause a major failure in the motor.
Along with valve springs, you will need locks, retainers, shims, and valve stem seals (16). The LT4 valve springs located in the LT4 "Hot Cam" kit should NOT be considered to be run with any cam due to the fact they are known to be very weak and only have a max lift rating of .540 which is not high enough for most off the-shelf camshafts.
B. Roller Rockers:
Purpose: Transfers the motion of the cam along the pushrods and assists the valves to open.
Benefit of Upgrading: Upgrading from the stock 1.5 stamped steel rockers to 1.6RR's will increase the lift that the camshaft is putting out as well as producing an extra degree or two of duration at the valve and increased overlap.
Ex: Lift of cc503 w/1.5 RR's = (.503/.510) divide by 1.5 then multiply that number by 1.6 to get lift with 1.6RR's = (.537/.544).
Required?: No, but highly recommended.
Popular Choices: Crane Golds, Comp Cams Magnums, Comp Cams Pro-Magnums.
SA or NSA?: Self-Aligning should work fine for some of the smaller camshafts that do not see revs past 6200/6300rpm. Non-Self Aligning is cheap insurance that can handle high rpm rev's better because the use of guide plates will ensure that the rockers cannot slip off the valve tips. NSA use 7/16" studs which is stronger than the 3/8" studs that most SA rockers have. Non-Self Aligning will require the use of hardened chromemoly pushrods, studs, and guideplates (8).
C. Pushrods:
Purpose: Transfers the motion of the cam to the roller rockers.
Benefit of Upgrading: A stiffer pushrod helps to reduce pushrod flex and along with the valve springs helps to keep the valves under proper control and away from valve float. Upgrading the pushrods is important for durability of the system and should be done when upgrading the cam.
Popular Choices: Chromemoly 5/16" or 3/8" outside diameter. Hardened chromemoly pushrods are required if using guide plates. The Trick Flow’s tend to be the most popular and proven choice.
Note: Pushrod length should be checked on any camshaft or change in the cylinder heads. There are a lot of variables that can change the length of the pushrods needed from camshaft base circle, deck height of the block, milling the heads, valve job height and valve length. If the pushrods are too long or too short they will cause premature wearing of the guides and valve train failure could be possible. LT1's with stock heads (assuming none of the mentioned changes have been done) will more than likely still use stock length 7.200" pushrods. It is so easy to measure pushrod length that it should be done regardless. A very easy to use tool to measure pushrod length is the Comp Cams pushrod length checker part# (7702-1).
D. Lifters:
Purpose: Rides along the lobes as the cam rotates around and follows cam up the lobe ramp which pushes the pushrods up.
Benefit of Upgrading: Over time with higher mileage motors the lifters tend to wear out.
Required?: No, highly recommended for higher mileage motors.
Popular Choices: GM LS7 lifters, Comp Cams hydraulic roller, Crane Cams hydraulic roller.
Note: Yes the LS7 lifters will work in an LTx motor, they are one of the only interchangeable components between LSx and LTx motors. If you go to your local GM dealer to order lifters for your LT1, they will give you LS7's because they are the newly revised replacements.
E. Others:
Gaskets: The following gaskets will be needed:
Front timing cover gasket, optispark seal, crank seal, water pump drive seal, egr gaskets, throttle body gasket, intake manifold gaskets, valve cover gaskets, water pump gaskets.
Timing Chain: Over time the stock timing chain wears and can develop slack. It is highly recommended to swap out the chain for a new one. A stock LT1 replacement chain from GM will do just fine for most.
Note: An LT4 timing chain will NOT fit on LT1 sprockets.
Valve Stem Seals: Worn out valve stem seals will allow oil to come up through the valves which leads to accelerated oil consumption and blue smoke coming from the exhaust. The perfect time to replace them is during a cam swap and for the low cost of them it should be done every time without doubt.
Optispark: If the optispark has not yet been changed it is a good idea doing so at this point. Whether you're doing the cam swap yourself or having it done by a shop, the optispark distributor has to come off. Therefore, it is the easiest time to replace it and will save you time and effort in the long run. If your having a shop do the swap it will not cost you any extra money to have it installed considering the old one comes off and gets re-installed again which will save you money of having it done again down the road.
Water Pump: Same goes for the water pump as with the optispark. If the mileage is getting up there or the pump is starting to show signs of leaking this is the time to replace it. It will save you time, effort, and money to do it at this time.
Conclusion:
Your typical cam swap will run roughly $1,000 in parts alone. That’s not including if you replace the Optispark or Waterpump etc. Labor depends on the shop and part of the country you live in but figure $600+. Tackling a cam swap yourself can easily be done with the right tools and patience. It is smart to start with bolt-ons before at all considering a cam swap. Without the proper intake and exhaust modifications a cam will be choked hindering performance greatly. If the car is auto it is highly recommended to put a stall converter in the car before a cam. Drivability will be poor and performance marginal without the use of a proper sized stall matched to the cam. Lastly, a tune should be on order after any cam swap. Poor drivability and performance will be the result of leaving the stock tune in while running a cam. I hope this guide proved useful to you and good luck with your cam swap! If you have any questions, concerns, etc. feel free to contact me.
StealthFormula @ LS1Tech
Hope that helps.
Pass Emissions?: No
Pass Emissions?: No
A. Valve Springs:
Required: YES.
B. Roller Rockers:
C. Pushrods:
D. Lifters:
E. Others:
Conclusion:
Hope that helps.
I notice that Crower has a very small LT1 cam they refer to as "Stage 1".
Chevrolet Hydraulic Roller Camshaft - LT1-LT4 - Chevy - Camshafts
208/216 114LSA 0.495/0.515 (1.5X)
This is the most helpful post I have seen on cam shaft selection. Thank you
My car is not a daily driver and it has developed a backfire / missfire @ w.o.t
looks like the opti is going bad. I think now is the best time for me to do the cam swap
as soon as my next bonus check comes in !!!
I have been looking at the cc503 cam shaft and know I have more confidence that I'm
making the right choice
I don't want to hijack this thread, but check your fuel pressure first. There are lots of things to check before jumping to the opti. It actually gets a bad rap.
I ran the XE503 in two cars and C4 Vette and 1995 Camaro. Worked well in both.
