LT1 slow to crank up..
Old Sep 30, 2003 | 10:48 PM
ninetythreez's Avatar
my car is not my daily driver. I crank it and run it about twice a week. When I go to crank it after it has sat more than 2 days it is really hard to crank. The battery is fine. The motor turns over but doesn't want to fire up until about 4-5 tries. I let it turn over several revolutions each time. after 4-5 tries it will fire but not fire right up. It tries to stall a few seconds, then comes to life. It has 120k on it, open exaust, 52mm tb, PP heads, relocated IATsensor, TB bypass. I guess new plugs/wires wouldnt hurt. Is my coil weak ya think? Should I have gas-shroeder valve checked? what else do you guys have coming to mind on this?? Thanks!!
Old Sep 30, 2003 | 11:39 PM
95CamaroZ-28's Avatar
I would check for a leaky injector or a weak fuel pump. If both of those check out alright, then I would start on the ignition.
Old Oct 1, 2003 | 04:10 AM
revtime's Avatar
Check your fuel pressure and see if its in spec.
Noer
Feb 28, 2015 11:29 AM
jb4xx
Feb 2, 2015 10:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
