Lt1 slight mod question
Old Jan 22, 2012 | 05:56 AM
MaroonMenaceZ28's Avatar
Alright guys im new to the site and srry to bark up this tree if anyone else has but I have a 94 z the following mods,cai,jet stage 2 power module,intake silencerdelete,de-screened maf,tb bypass, fulltime fans, 2 3/4 inch exhaust with moroso spiral flow muffler, jasper trans with a shift kit, and 3.73 gears and 100 wet shot.. The car is supposed to have high compression rod and pistons, ported and polished heads and a small cam..and my buddy has a 99 z28 with slp lid and exhaust everything else is stock..he has called me out at this years spring shootout i know i can beat him with spray but any idea what i may do all motor against him thru the quarter and what it may run? Thanks for any input yall may have
Old Jan 22, 2012 | 07:32 AM
Re: Lt1 slight mod question
Your mods list is not compatible. You indicate heads and cam, but no tune. The JET module is sort of worthless on a stock engine, and can't compensate for a modification as significant as heads and cam. Also don't see anything in the way of headers or larger injectors. 2-3/4" is the stock intermediate pipe size. Even a stock engine benefits from a 3" catback. Descreening the MAF sensor is storngly discouraged. Not sure why you have your fans running full time. A 160* stat and reprgrammed fan temps will provide better results.
How does it run?
Even a stock LT1 with a 100-shot should have no problem with an LS1 with a lid and exhaust.
Old Jan 22, 2012 | 08:23 AM
mrmint69's Avatar
I was told all kinds of things by the previous owner. Only the things that I could see were true. What do you have for proof and what are you 100% sure you have? If the motor has all the things you guess it has, you really want to get the thing tuned. I put headers on mine and added a cutout right after the high flow aftermarket cat. Do you have any times or dyno numbers as to how fast the car is now? I was told the car had a different more aggressive cam, but the car was totally stock internal after checking further.
Old Jan 22, 2012 | 09:37 AM
How does it run?
The car runs very strong i have ran the ls1 on the street,.. Off the line i spun 45or 50 ft and redeemed traction,, i started catching hit thru the 1/4 and he beat me by 2 1/2 - 3 car lengrhs
Old Jan 22, 2012 | 09:54 AM
You sprayed a 100-shot, and he beat you by 2-1/2 - 3 car lengths?
Old Jan 22, 2012 | 11:32 AM
No we were all motor he caught traction i spun 45-50 ft and he beat me by 2 1/2-3 lengths but i was closing the gap pretty good towards the end
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
cmdeshon
Dec 27, 2014 10:06 AM
cristian1311
Nov 23, 2014 02:22 PM
