lt1 sensor list?? need help
guys im in the middle of swap into a 91 rx7. all i have left over from my last build is a 355 block, heads, intake, and t-body. also a burned up 4l60e. anyways, perphaps you could help think of all the sensors on the lt1. im !egr and smog stuff. also if anyone has a cheap 95 lt1 wiring harness (auto) i sure could use one.
Re: lt1 sensor list?? need help
Shoebox has the 95 LT1 wiring diagrams on his website. They show all the sensors and actuators controlled by the PCM. That should be about all you need.
http://shbox.com/1/4th_gen_tech2.html#1995_pcm_wiring
Jul 4, 2005 05:00 PM
