LT1 Running rough
LT1 Running rough
Hey, I got a 96 Z28 auto...113,000KM
I bought MSD 8.5 Wires, with Delco Platinums... I got them put on by a mechanic, and car ran beautifully for the first day or two, then suddenly the car started to run like a bag of #$%^...
A couple weeks back I got the water pump replaced because it was leaking. Hopefully it didnt damage the opti<-- what does that mean anyways?
I get a blinking engine light too but only when accelerating but when I am at a cruising speed it goes away.... Got a scanner on it, and there were no codes!
WTF is going on!!!
I just want my car to run smooth again
WTF is going on!!!
Re: LT1 Running rough
No one told you about the Opti! Wow. It's short for the Opti-Spark distributor. It's located behind the waterpump. It's sandwiched in the worst location possible. If your waterpump leaked, odds are it leaked on the Opti. The Opti is usually the first culpret with ignition issues. For your sake I hope it's not, if you first got the car and it's out..you'll be dropping some money down to have it replaced. Or, you can have a learning experience it and do it yourself.
It looks intimidating, but it goes quite smoothly if you take your time. Have it scanned. Correct me if I'm wrong but I think the OBDII will throw a light if there's opti trouble.
Do you know of any modifications to the car? More info would help.
don'tttttttt jump on the opti wagon!!!!!!!
lets use some basic troubleshooting here! If the water happend a few WEEKS ago we can just say its the opti.
if your check engine light is flashing, get some codes and come back.
Either that or one of your plug wires got too close to your exhaust manifold and burned through the insulation and is arcing against it. Mine did that with 2 sets of MSD's. Very easy to do especially if you route them wrong and don't zip tie them in place.
sounds like the mechanic didnt tie the wires away from the exhaust man. and one or two got burnt. start the car at night and open the hood with as little lighting around as possible and look for some arching. good luck
The SES light will flash when a missfire is picked up a solid SES light is not a missfire.
Here's a link to the thread I posted; you might find some help there; http://web.camaross.com/forums/showthread.php?t=460597
Or get some OVC Taylor wires for like... 80-110 dollars? and be done with it lol I really think wires are your biggest culpret(sp?) Do you still have manifolds or headers?
I got some nice 6" fire boots cause i was scared of burning my MSD's on the stock manifolds
