lt1 rebuild opinions
Old Mar 16, 2010 | 09:08 AM
jklopez09's Avatar
I finially got my 93 z28 running after what seemed forever. But now i've decided to rebuild my old engine for a lil more power. these are what im planning on doing and was hoping you guys can tell me if its the best route, how it will run, and if i need anything esle. thanks for all help.
bore block 30 over
rebuild kit CSMHP766-300 or CSMHP765-300 from summit?? not which one to use
cc305- i know im using this
1.6 roller rockers
pushrods?
long tube headers
chip
LE1 heads-im not really sure about heads. it will take most of my budget on the above so probably will use stock heads with springs to match cam if i run out of money
Old Mar 16, 2010 | 10:52 AM
brucer's Avatar
i went .030 bore and .01/.01 on my crank. i used summit CSMHP766-311
if you dont need to grind your crank use csmhp766-300
the kit has coated speedpro forged pistons with fel-pro gaskets, speed-pro rings, pioneer freezeplugs... pretty nice kit
when you assemble the engine use victor reinz 5898 head gaskets their thinner and will bump your compression up a little..
i'm reusing using stock pushrods and lifters..
i'm going to convert to an electric waterpump when i assemble my engine, so i got a double roller chain also..
dont forget you have to have your rotating assembly rebalanced, use a neutral balance flexplate or remove the weight from your stock flexplate..
i used the lt4 hotcam with springs, locks, and retainers got it for $200 new in box, couldnt pass it up..
i'm deleteing air and egr at assembly
i'm going to use pcmforless for my retune
Old Mar 16, 2010 | 01:17 PM
rskrause's Avatar
Moderator
Does it need to be rebuilt? If not, just do the heads and cam.
Rich
Old Mar 17, 2010 | 05:50 AM
jklopez09's Avatar
yea it needs to be rebuilt because its been sitting for a while outside. i got a guy going to help me put it together once i get all the parts and the block ready. but how can i tell if i need to grind the crank? the engine ran and wasn't knocking or anything when i replaced it, but it had something go wrong with the valves and was skipping and stalling out.
Old Mar 17, 2010 | 11:48 AM
Jlo's Avatar
Jlo
I would take the crank to a machine shop and get it checked..if it doesn't need to be cut to .10 you can simply have it polished that's what I did and only paid $20.00 to have it done.
Sergio
Jan 27, 2016 04:27 PM
Not Dave
Dec 11, 2014 06:32 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
