LT1 rear seal leak question
Old Mar 28, 2006 | 04:26 PM
chas's Avatar
I bought a 97 Z28-SS with 67000, miles! Both the front and rear seals leak oil from the engine.
Just wonderd if the LT-1 was known for rear and front seal leaks?
Chas
Old Mar 28, 2006 | 05:44 PM
RE AND CHERYL's Avatar
Re: LT1 rear seal leak question
Not really. No more than any chevy SB. The intakes are prone to leak though. Sure you don't have a intake gasket leak?
Rear main is a bitch to change.
Old Mar 28, 2006 | 06:04 PM
BlackDog's Avatar
FYI... When you do change the rear seal, run your finger nail over the area where the seal was riding on the crank. If you can feel a slight groove you should install a metal sleeve over the crank or the new seal won't do its job for very long.
Just my 0.02
Old Mar 28, 2006 | 06:24 PM
blown94's Avatar
what he ^ said. Its called a crank saver. you probably wont need it. Its probably your rear intake gasket area. Check that first with a mirror if you can. There are 3 seals on the front timing cover. Opti, water pump, and crank seals and also the oil pan gasket. It could just be the front also, leaking back and making it look like the rear is leaking.
Old Mar 28, 2006 | 06:28 PM
chas's Avatar
Thanks for the help guys, i will have my performance guy check over the engine for intake leaks. He did say both seals are leaking! I will have him check for the groove as well.
I bought the car pretty cheap, the car looks about new inside and out, for a 9 year old car, it was well taken care of.
I was amazed with how much low end power the car has, out of the hole the z28 is just about as fast as both my 99 and 03 Ford Lightnings!
I'm pretty sure the car is stock, but it does have a body kit and after market hood, and 18" rims with new Toyo 18-40-245's up front and 18-35-295's in the back.
For mods i would like to do a cold air and rear gears!
Chas
Old Mar 28, 2006 | 09:16 PM
OBE1 95Z28's Avatar
Fairly common for the front leak to be the water pump drive gear seal.
Patricklt1
Apr 24, 2015 06:29 AM
Jazsun
Dec 29, 2014 12:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
