LT1 question
Thanks trying not to sound dumb, just new to FI. Built a lot of drag cars but all old school. So how much comp. does a LT1 have stock? And how much can you safely run with 93-94 octane? Looking @ some Howards forged pistons and they said it produces 10.5:1 comp with 64cc heads so I was figuring around a little over 11.1 comp with the stock 54cc heads.
Are you planning a build? Redoing the bottom end? Are you leaving the valvetrain stock? What's the deal?
D Port exhaust ports too, among a few other small differences.
yeah looking at picking up another motor from a friend of mine. Plan on using a steel crank, h beam rods, ported heads and intake, forged pistons and a Voodoo cam the spec's are as follows dur @.50 243/251 lift .560/.565 LS 110. Not sure 100% on the cam, might go with a soild roller. 4.10 gears and a 6 puck ceramic clutch. Not sure on TB size or INJ size have to find out what to use. Trying to get around 450-500hp. NO POWER ADDERS.
You need some direction! Read up on other people's combos and see what they're using instead of throwing a modge-podge of parts together and hoping for the best.
What are you shooting for as far as displacement is concerned? 355, 383, 396? For 450-500hp (assuming crank HP), you won't need h-beams as I-beams will be more than enough and save yourself some money. Additionally, a SR valvetrain will likely be overkill as well.
