LT1 question
Old Dec 17, 2009 | 10:58 AM
mike 1972's Avatar
LT1 question
I'm new to the LT1 area and have a question about the motor. Are the heads the same on the LT1 as they are on the earlier 350's?
Old Dec 17, 2009 | 11:11 AM
moparman's Avatar
No.
Old Dec 17, 2009 | 11:33 AM
deerslayinrenek's Avatar
Originally Posted by moparman
no.
......x2
Old Dec 17, 2009 | 12:15 PM
mike 1972's Avatar
whats the diff?
Old Dec 17, 2009 | 12:17 PM
RamAir95TA's Avatar
Originally Posted by mike 1972
whats the diff?
LT1 heads use reverse flow cooling (the water pump cools the heads first, then the block, allowing for greater compression), so the coolant passages are entirely different. We use a dry intake manifold, so coolant never gets to the intake manifold.
Old Dec 17, 2009 | 11:51 PM
mike 1972's Avatar
Thanks trying not to sound dumb, just new to FI. Built a lot of drag cars but all old school. So how much comp. does a LT1 have stock? And how much can you safely run with 93-94 octane? Looking @ some Howards forged pistons and they said it produces 10.5:1 comp with 64cc heads so I was figuring around a little over 11.1 comp with the stock 54cc heads.
Old Dec 18, 2009 | 12:03 AM
henryz28's Avatar
Should have no problem with this set up. You can even go higher to 12:1
Old Dec 18, 2009 | 09:22 AM
mike 1972's Avatar
WOW you can go that high with pump gas and still drive it on the street! Man guess it does make a diff with cooling the heads first.
Old Dec 18, 2009 | 11:31 AM
RamAir95TA's Avatar
You can go even higher. Many guys (including myself) are closer to 13:1 on pump gas and I drive it all the time. As long as your cooling system is up to snuff and you have a good tune, you'll be fine. LT1s come from the factory with 10.5:1 static. Keep in mind static compression is just a solid figure on the build dimensions of the engine and has no bearing on performance - it's the dynamic compression ratio that's more important.
Are you planning a build? Redoing the bottom end? Are you leaving the valvetrain stock? What's the deal?
Old Dec 18, 2009 | 11:34 AM
6SpdLT1Z's Avatar
D Port exhaust ports too, among a few other small differences.
Old Dec 18, 2009 | 11:50 AM
mike 1972's Avatar
yeah looking at picking up another motor from a friend of mine. Plan on using a steel crank, h beam rods, ported heads and intake, forged pistons and a Voodoo cam the spec's are as follows dur @.50 243/251 lift .560/.565 LS 110. Not sure 100% on the cam, might go with a soild roller. 4.10 gears and a 6 puck ceramic clutch. Not sure on TB size or INJ size have to find out what to use. Trying to get around 450-500hp. NO POWER ADDERS.
Old Dec 18, 2009 | 11:54 AM
RamAir95TA's Avatar
What are you shooting for as far as displacement is concerned? 355, 383, 396? For 450-500hp (assuming crank HP), you won't need h-beams as I-beams will be more than enough and save yourself some money. Additionally, a SR valvetrain will likely be overkill as well.
You need some direction! Read up on other people's combos and see what they're using instead of throwing a modge-podge of parts together and hoping for the best.
Old Dec 18, 2009 | 12:14 PM
mike 1972's Avatar
Was looking at staying a 355 cid. no more than a 383 at the most.
Old Dec 18, 2009 | 12:28 PM
RamAir95TA's Avatar
Well pick one...hahah. There is a different method to each choice.
Old Dec 18, 2009 | 12:51 PM
mike 1972's Avatar
355
