LT1 probs: will start then die
need some advice from anyone who wants to...
car will start, then die, as if its starved for fuel....have tried MAF, fuel pressure is 36 psi, fuel filter not too long ago, plugs wires recently....
funny thing is it runs fine once it gets started....only prob is when i start it....oh ya, sometime it will start without a problem....this car is possessed!
any suggestions, post up!!
gonna pull tha IAC sensor out 2morrow and see what happens.......shouldnt be too difficult swapping it out with out pulling anything off the car is it.....or must you pull the TB???
good thing i work at a parts store w/ 20% discount.... i live in Lubbock where scoggin dickey is.....72 for that thing, i get it from advance auto parts (work) for 30 sumthin....thank god for employee discounts!
you guys think this would help cure hard starts? like overly long cranking b4 firing? runs fine once it starts, just hard starts all the time, unless started just a couple minutes after shutting off then it fires right up
thanks
thanks
Originally posted by 93formula
i just unpluged my iac, mines a 93 so i dont know if it will work on yours. now i just give it some gas and it starts up fine.
Originally posted by Fastbird93
You started the car with the IAC unplugged???
also the fuel pump relay could be a culprit to hard initial starts. mine did that too
