lt1 pop from intake
lt1 pop from intake
so ive got a 95 M6 Z28 it has around 73,000 miles on it, i bought it wrecked and fixed it, ok heres the weird thing the car runs good, seems to idle fine but a lil high around 1100 rpms, but if i go up a hill in 4th or 5th gear and put it to the floor it pops out the intake, it has new plugs, wires, opti, map sensor, iac valve, 4:10 gears,cai, and a programmer and only ran a 14.7--seems a little sick to me? idk does anyone have any clue what could cause this? ITS KILLING ME thanks
I had a bent valve and it backfired really bad through the intake but it wasn't drivable.
Do you have cats?
That can be so many things, fuel, trans, clutch, ignition, dirty or clogged injectors, low compression not really enough info but im guessing you dont have any check engine light on or you would run codes sometimes they come and go letting you know periodically that something is wrong.
If this list of mods is all you have done to your car then your idle shouldnt be higher than 600 rpm stock is 550 rpm. So id be checking my iac, fuel would not be causing this either. To me if it were idling that high then it would seem that it would sound kind of rough which a car with yor mods should not. How much have you driven it since the rebuild after the wreck and has it ever worked properly since the rebuild.
ive driven it about 2000 miles its done this ever since i repaired the car it had a few vac leaks when i fixed it hoses etc. had popped off during the accident ,it has a new iac, it seems to run a little rough but its not real bad, another thing if im driving through town it seems to shake when im in a higher gear kinda like it doesnt have enough power to pull --btw thanks for the help guys
Hey man if it happens when you put it in higher gear when going up hill you might be putting it into the next gear too early which always causes a car to bog down like your describing. LEt it rev up a little before you pop it into the next gear and see what happens i done know how much youve driven stick shifts but thats what it sounds like to me and i and you both better hope thats what that is. Good luck man and always check all fluids after a major rebuild expecially after your through with the first outing of driving around.
Sounds like a lean misfire. I would check fuel pressure,vacuum leaks,maf readings at idle,fuel trims at idle,cruise and slight load. Should not do it long enough to set a code. The high idle makes me think vacuum leak
formula218
Dec 2, 2014 04:27 PM
