lt1 optispark
Old Mar 3, 2010 | 11:44 PM
gforce91's Avatar
Cool lt1 optispark
ok so my water pump died and took the optispark with it. im looking to replace it. any sugestion, i was lookin at the summit racing opti and the gm performance opti is there any difference, except the price. summit brand is like $100 cheaper. any suggestions would be a lotta help thanks!
Old Mar 4, 2010 | 01:55 AM
edz97's Avatar
Most recommend thepartsladi on ebay for the opti. I am rolling with a sub 100 dollar one from ebay and it seems to be fine.
Old Mar 4, 2010 | 08:00 AM
brianswimmer23's Avatar
all i can say is that you need to go to the parts ladi so you stay with an OEM type of opti, and that you need to start doing some preventative maintenance by doing the weephole mod.
Old Mar 4, 2010 | 08:51 AM
bobdec's Avatar
From what I have seen unless you are into above 5800 RPM (stock limiter setting) the original equipment Delphi or old Delco optis are the most cost effective and reliable units.. The off shore optis sell for less but seem to have a higher failure rate, if you don't mind the gamble the option is up to you. For higher RPM a mix of the MSD cap/rotor and the OEM opti is also popular choice. As stated above, 'thepartsladi' on ebay has been the lowest cost seller of OEM optis. Back to your OP.. GM performance probably sells the same unit as the partsladi, not sure what manufacture the Summit unit is made by, I would give them a call to verify if it's OEM or off shore. Then you can make your decision..
Old Mar 4, 2010 | 12:10 PM
Not really a "Computer......." forum topic. Let's move this to "LT1 Based Engine Tech".
Old Mar 5, 2010 | 12:15 AM
Fatdog2's Avatar
Hold on there.Before you replace the opti,get the water pump replaced,and dry out the opti first.Who knows?it worked for me.Anybody got a hair dryer?Beer time.
Old Mar 5, 2010 | 09:17 PM
97venom's Avatar
If you do need one thepartsladi is the way to go
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
