LT1 OIL pan
Old Oct 4, 2003 | 09:24 PM
MY91Y84's Avatar
LT1 OIL pan
i did an LT1 swap and i notcied i big threaded hole int he oil pan right baout the drain plug...is that were the oil pressure switch goes?...if not then were does it go?...id like to use my 91 L98 oil switch if possible...if not can the hole be plugged?
thanks guys
Rob
Old Oct 4, 2003 | 09:37 PM
BlackDog's Avatar
That's for the low oil sensor.
Scott
Old Oct 4, 2003 | 09:54 PM
MY91Y84's Avatar
so i can plug that hole then?....
were is the oil pressure switch at?....or do LT1's even have them?
Old Oct 4, 2003 | 11:09 PM
carlos64030's Avatar
The oil pressure sensor is located on the top left hand side on the rear of the engine block, right behind the intake manifold.
Old Oct 5, 2003 | 07:02 AM
BlackDog's Avatar
[QUOTE]Originally posted by MY91Y84
[B]so i can plug that hole then?....
Yes.
Old Oct 5, 2003 | 11:16 AM
Unless its an LT1 from a 93. They have the oil pressure sending unit on the side of the block, right above the oil filter.
Old Oct 5, 2003 | 11:32 AM
MY91Y84's Avatar
thanks guys...its a 94 motor..
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
