LT1 OIL pan
LT1 OIL pan
i did an LT1 swap and i notcied i big threaded hole int he oil pan right baout the drain plug...is that were the oil pressure switch goes?...if not then were does it go?...id like to use my 91 L98 oil switch if possible...if not can the hole be plugged?
thanks guys
Rob
thanks guys
Rob
Originally posted by carlos64030
The oil pressure sensor is located on the top left hand side on the rear of the engine block, right behind the intake manifold.
JasonD
Aug 23, 2010 03:14 PM
