lt1 off of a caprice
Old Jun 8, 2008 | 02:25 AM
djexotic08's Avatar
i was at the junkyard today. get replace my glovebox. and also looking for a boneyard motor. not a single camaro and firebird didn't habe a motor in also the part i was trying to find. but i came across of this caprice that had the lt1. the guy told me that he sell me the motor for 175 dollars plus 50 dollar charge to use his stand and chain lifer(it's power by a wrench with a car batti.) should i got for it or not?
Old Jun 8, 2008 | 02:27 AM
bombebomb's Avatar
Couple things to note about the "lt1"
Make sure its a 350 lt1 and NOT the baby 4.3 LT1, from what iv heard they look the exact same.
Also the caprice LT1 has a slightly smaller cam also.
Old Jun 8, 2008 | 02:40 AM
Green96Z's Avatar
The Caprice LT1 also had iron heads, not aluminum like the F-body LT1.
Old Jun 8, 2008 | 02:54 AM
bombebomb's Avatar
ah, completely forgot to mention that, was to into warning him about the 4.3
Old Jun 8, 2008 | 03:55 AM
djexotic08's Avatar
ya know i got a camaro!!! with the lt1. the 4.3 is not in that car. but the motor got iron heads. sh#t! but i wanna get it and rebuild the motor. i going to replace the heads with some edelbrock heads. but should i get it or not!!
Old Jun 8, 2008 | 04:56 AM
bombebomb's Avatar
Up to you, I mean if your gonna rebuild it, any lt1 350 block will do wont it?
Old Jun 8, 2008 | 07:27 AM
94zgreenmachine's Avatar
$175 is fairly cheap for the whole thing, let alone the block , seeing as how I have seen alot (block only)for that price or more and you would still have to pay for shipping, etc.
Are you just doing a stock rebuild on the bottom end? Turn the crank, resize the rods?
I bought a used block. I still have my original block. Dreaming of an all out build, just not sure if it'll be turbo or what.
Old Jun 8, 2008 | 10:03 AM
96capricemgr's Avatar
The Caprice if infact a LT1 is the same exact shortblock as an f-body so it will work. The Edelbrock heads on the otherhand are a bad choice. You realize their heads and cam package puts less to the flywheel than a good heads and cam package puts to the tires.
Old Jun 8, 2008 | 12:14 PM
djexotic08's Avatar
i am rebuild it from ground up. i trying to hit 12 on the strip!
then what value heads that is good out their!!!
Old Jun 8, 2008 | 12:15 PM
TheChronic's Avatar
Don't be so sure. They do look EXACTLY the same. Check the SPID label on the trunk for "LT1" to make sure.
Or the VIN, 8th digit: P = LT1, W = L99 (4.3)
Old Jun 8, 2008 | 12:53 PM
djexotic08's Avatar
i go back to check when i get some shock's for my trunk! but, check out this video. this is what i find when i open up the hood of the caprice. and yes, this car i was looking at the junkyard had 20 inch rims and a stereo system.
http://www.youtube.com/watch?v=NoLvAtBIVLs
Old Jun 8, 2008 | 01:28 PM
I'd agree with Dwayne, the edelbrock heads aren't a good choice. They are pretty much the same as stock. Save your cash and get a head /cam package for a few hundred more.
Old Jun 8, 2008 | 01:29 PM
Check the stamping on the block. The rear should say "5.7L" or look for the 327 number on the block towards the front.
Old Jun 8, 2008 | 01:43 PM
LOW-LIFE's Avatar
to add to that...
passenger side near the knock sensor.
SinisterRacing1
Mar 7, 2015 03:44 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
redzed
Aug 31, 2002 01:00 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
