LT1 no start, no spark, 2 opti's
Old Aug 14, 2008 | 04:07 PM
BCdawg57's Avatar
I am begining to get extremley frustrated with this engine. I swaped a 94 into my 91 camaro.
My problem originated with no spark. I had a brand new wiring harness, brand new coil, a tested good ICM, brand new GM opti, a computer ive never witnessed running.
I did shoebox's opti test, and wasnt getting any AC pulse at the ICM connector. Replaced the opti, and i still get no pulse. I have .4 volts ac at terminal b constantly with the key on. Everything has the power it should.
My computer was tuned by trifecta, which uploaded flawlessly, and when i used his tuner as a scanner i first got code 42, and then code 16. that is when i replaced the opti. Now right now i have no acess to a scanner, but as i said im still getting no ac pulse. Right before i shipped the scanner back i did pull a code 42 again, but didnt think anything of it cause of misc plugs that were probably disconnected. Possible my PCM is bad?
Im at a loss and i dont want to spend 200 on a hunch.
please help
Old Aug 15, 2008 | 05:32 AM
Guest47904's Avatar
Guest
The AC signal you are looking for is with the engine CRANKING!. Not merely with the key on.
But I think your problem is more fundamental than that.
Old Aug 15, 2008 | 10:17 AM
CGrant's Avatar
please help
you should get 1-4v while cranking at the trigger wire, on my 95 its the white wire, not to be mistaken with the white/blk wire.
make sure you have a pulse at the trigger wire 1 to 4v (while cranking), do you have spark at the coil?
when you say the icm was tested good...did some place along the lines of an autozone test it? if so i wouldnt trust autozone for anything...i only buy stuff from autozone like oil, filters, etc unless i just need to get something running like now...
Old Aug 16, 2008 | 03:40 PM
BCdawg57's Avatar
well i figured out what it was. i had my iat and icm plugs swaped. lol. i called the speartech and told him the colors of the wires and he figured it out for me. always the simple things.
Noenav
Mar 1, 2019 07:38 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Injuneer
Dec 15, 2014 09:36 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
