LT1 No PCV valve ?
Old Aug 13, 2014 | 03:20 PM
4586's Avatar
LT1 No PCV valve ?
Just noticed that this 95 LT1 doesn't have a PCV valve....direct vent? When did they stop using PCV valves?
Old Aug 13, 2014 | 04:53 PM
Pullngz's Avatar
Re: LT1 No PCV valve ?
Should be on the passenger side of the intake, centered front to back. It connects to a port below the throttle body.
Mike
Old Aug 13, 2014 | 05:00 PM
Actually, it's on the driver side of the intake manifold.
Shoebox has a photo of it.
You were probably looking at the line from the throttle body to the passenger side valve cover, and expecting it to be the elbow that plugs into the valve cover. That line supplies filtered, MAF measured air from in front of the throttle blades to the valve cover, where the vacuum from the PCV valve on the other side of the intake pulls it through the crankcase to remove the harmful blowby products.
The vacuum source for the 95-97 PCV system is the intake manifold port under the throttle body.
Old Aug 13, 2014 | 05:08 PM
It's also shown on the emissions routing label on the radiator cover, again, courtesy of Shoebox:
http://shbox.com/1/emission_hose_routing.jpg
Old Aug 13, 2014 | 05:18 PM
Pullngz's Avatar
I stand corrected, I knew it was on the DRIVERS side, and still typed passenger.
Old Aug 13, 2014 | 06:44 PM
4586's Avatar
Fred
Thanks you are right on..the PCV valve doesn't stick out as you would normally expect. What started this is that I am planning on installing after market valve covers and studying the valve cover ports required.
The elbow (line) on the passenger side doesn't appear to have any filtering inside..should it?
Ed
Old Aug 13, 2014 | 07:48 PM
Chimera96's Avatar
Originally Posted by 4586
The elbow (line) on the passenger side doesn't appear to have any filtering inside..should it? Ed
No filter on that line
on aftermarket VC, get "LT1" specific. The PS one is notched to clear alternator. Pulling alternator apart and rotating rear case has worked for some using non-notched SBC valve covers.
Old Aug 13, 2014 | 08:19 PM
bw_hunter's Avatar
Actually you need F Body specific LT1 VC..the other versions don't have the alternator mounted differently...
Old Aug 13, 2014 | 09:49 PM
4586's Avatar
The engine is going in a streetrod...have the alternator mocked up "down low"...should make it easier to locate valve covers.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
thenewkid
Nov 29, 2014 04:54 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
